MY DAMN POWER WINDOWS! ITS BEEN TALKED ABOUT TO DEATH, BUT THIS IS A NEW ISSUE
Last night, I removed the door panels from both rear doors, removed all connections and disconnected the battery for 2 hours. Upon reconnecting only the battery(leaving the rear doors mechanisms fully disconnected), my front windows were still unable to go up or down. I've done the simple test to see if the front window motors were the issue by seeing if the interior lights dim while the window switch is activated, and they didn't. Also, when the car is in the accessory position(before starting the car), and I try to roll the front windows up or down, I hear something(which sounds like it's in the trunk) clicking. When I press either front window up or down, I here a click. I'm not sure if there's a rear module trying to engage, but I'm anxious to know if you've heard of this issue. I would greatly appreciate your response. Thank you
FYI, I'm not a novice, I put a new engine in this car by myself a couple years back, but this issue is something new to me. Thanks
EDIT: I found out where the clicking is coming from, it's the "Window Comfort Switch" that's hidden by the battery in the trunk underneath the metal, but accessible when the battery is removed. The rear windows still work fine, but is there a fix to the "Window Comfort Switch" that will stop the clicking when the front window button is activated, so the windows will work?
. They usually have a solder failure and work sporatic. If you take the cover off the module run a soldering gun (thin tip like from radio shack) accross the soldered area and it will re solder it. You'll probably see the lines in the cracked solder if you use a magnifying glass.
Now since the window switches (in the console) are still engaging the “Copper Magnetic Mechanisms” in the Window Comfort Module, the window switches can’t be the issue right? My understanding is there can only be 3 reasons on why only the front windows aren’t working….
1) The Window motors are bad.
-But how can both front window motors go out simultaneously? Also, I did the simple window motor test. Having all the interior lights on and trying to roll the front windows up & down, which is supposed to make the lights “dim” if the window motors are the issue, but the lights didn’t dim.
2) The Window Comfort Module is bad.
-Clearly I replaced it, but the same exact problem was happening when my old Window Comfort Module was in… Which was… only the rear windows were working.
3) The Window Switch(in the Console) is bad.
-If this was the issue, why are the window switches still activating the “Copper Magnetic Mechanisms” inside the Window Comfort Switch… Is this even possible when the window switches go bad?
As you can see, I’m at a loss about the issue and winter is coming. I tried to be thorough in my response, so let me know if any of you need clarity on something. Thanks
Obviously, your problem is not the same, especially when they were working before, so for a few $$$$ it will be worth it to get it fixed.
Good luck
Good luck
1) Going with your instinct that the Window Comfort Module, Window Switch & Window Motors aren't the issue = Zero Dollars ($0)
2) Looking closely at the Window Comfort Module's Fuse in the rear fuse block to see that, though the circuit didn't break, the corner of the 30 AMP fuse had melted, so I needed a new 30 AMP fuse = 15 CENTS ($0.15)
3) Not taking PTCruiser's advice, which was the obvious thing to do if you wanna shell out stupid amounts of money, which obviously would go against the whole reason of even posting my problem on this forum = PRICELESS!
No love lost PTCruiser, though you offered an innocent, but obvious suggestion which I was trying to avoid by even posting this issue on this forum, the issue is now SOLVED by replacing the fuse... MY WINDOWS ARE BACK!!!! Thanks to all who helped!
Mechanically, I will take on any challenge.
Going nuts over the same problem for three months!
Thank you
