quick question, C200 W202
i have 1999 Mercedes-Benz C200 W202 Sport.
the issue is:
- elec mirrors dont work,
- both the front and left rear power windows dont work.
the sunroof does and so does the rear right passsanger power window.
(note: by "dont work" i mean they will not go down if i press the buttons)
ive been reading on this forum and others, its ether a syncronising issue or the rear left motor is damaged?
how would i be able to re-sync them if they dont go down?
(does this mean its not a sync problem)
and is it as simple fix, i.e disconnect rear left and the front might work again?
thanks.
everything but the rear left window works... well they all did but my drivers window has stopped again.
this being the case, would it be best to just disconnect the rear left?
does this allow the rest of the electics to work? because randomly one day after i had replaced the fuses my central locking stopped altogether.
but i had read you just need to open and close the boot a couple times and that worked for me.
im just wondering if my electical problems all stem from the rear left motor being faulty.
anyone who has this issue or similar check out this:
http://homepage.eircom.net/~decdec/m...new_page_1.htm
