rear fog light switch bulb
2006 smart cdi
Hi, everyone! Let me pick your brain a little bit...
Both the front and rear fog lights are working fine in my 94 C280, but the orange indicator on the switch itself is not coming on. Does anyone know how to replace the bulb inside the switch? I noticed in my Haynes manual wiring diagram that there is such a bulb in there, but how does one get to it? Also, does anyone know what type and size this bugger is?
At some point I would like to modify the rear fog light assembly to allow both the left AND the right side lights to increase in brightness, like the left side does right now. I live in the South, where fog is an almost daily road hazard, and would like to add to my car's visibility for safety...
Any ideas from the experts here?
TIA,
Serge
TIA,
Serge
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: rear fog light switch bulb
1) Mercedes only illuminates one rear fog light because this has proven to be safer.
2) If you add another rear fog light by just connecting a wire from the left side to the right side, you will be exceeding the current carrying capability of the wiring harness, for long term use. If you do not have a bulb failure warning on your fog light (it's possible you don't have this in a 1994 car), then you can replace your bulbs with LED bulbs (just for the fog lights) and reduce the required current. Then the single wire would be within spec.
-s-
02 W163, 84 W123, 03 E39, 98 E39
Re: Re: rear fog light switch bulb
Originally posted by scorchie
I'm not an expert, but I'll add my opinion...
-s-
-s-
To replace the small indicator bulb for the rear foglights you need to pull the headlight switch off. You know how the switch pulls to you one click towards you for front fogs and two clicks for front and rear fogs? With the light switch in the off position, just pull it to you and it will pull off the stalk that holds it. It is only held on by friction. You will find a little bulb there that needs to be pulled out and replaced. I do not know what the designation or number is. If you have a MB dealer by you, you could pick one up at the parts counter.
The older MBs (80's) did not have the rear foglights wired, and we had to get bulb holders, reflectors and run a hot lead from the light switch to get rear fogs. MB has alwayse only had one light, where-as other European Co's put two. My feeling is that two bright lights will be mistaken by other dirvers as a "driver riding their brakes." MB has always had the left rear light be the fog, (in countrys where we drive on the right). My thoughts are that they do this so that drivers will know which side to pass on.
Why be like other European Vehicles and have two rear fog lights?
Re: Re: Re: rear fog light switch bulb
audi also has one rear fog light. it is common practice for them to add a second one on the right side taillight.
Re: Re: Re: Re: rear fog light switch bulb
Originally posted by rotorgasm
so people dont always pull you over and tell you "one of your taillights is out."
You can't win. Either the un-informed American drivers either think you are riding your brakes, or have one "brake light" out.
I'm not sure about the reasoning for this, because then who is there to see it?
-s-
2006 smart cdi
Thanks for the replies, scorchie/sph17 and rotorgasm!!
I will replace the switch indicator bulb asap.
About the rear rt fog light: I noticed that the lt rear fog light uses the same bulb that the (red) parking light uses, but it uses a second element in the bulb. It only comes on if the switch is pulled to the second notch. The brake lights, on the other hand, are separate. So, if I adapt my rear fog lights to work both on the left and rt sides, wouldn't that just increase the brightness/visibility-of-my-car from the rear? The brake lights would still operate normally...
What do you think????
Thanks for your inputs!
Serge
Serge
Serge
Serge
-s-
Rear Fog Light Bulb
Serge
Serge
There are 50W bulbs, and also Halogen bulbs made that fit into that type socket for people who want brighter rear lights, but you might melt the plastic lens and reflector, and may draw more amps than the circuit is designed for. Be careful of modifications or alternate bulbs.
You are too modist as many people look to you for definitive advice for their problems.
I'd add to your helpful instructions, that while you're behind the switch, consider taking a socket and tightening it up. My C43 switch loosened over time so that the switch would rotate slightly... it gives it a nice solid feel to have it tight!
-s-
2006 smart cdi
Thanks to all for your helpful info. For now, I will cease and desist my attempt to have two rear fog lights. I have to research it further. The LED idea seemed feasible...
The headlight switch foglight indicator bulb was replaced easily, as described by y'all and my indy shop had them in stock for $1.09. Probably the cheapest Benz part I will ever buy...
About the left rear fog light bulb specs, I have the same bulb in both the left and right side position/parking lights. They both have 2 elements, though the second one on the rt side is not used, for now... The housing that holds the bulbs has inprinted the type bulb to be used and reading the numbers from the body, they seem to correspond... My car is a 94 C280, and as far as I can tell, these are the spec bulbs... I can't recall the designation right now... What bulbs do u use on your car, sph17?
Thanks again for all your inputs. I am still very green on my first Benz and willingly accept all comments.
What a great forum!!
S.T.
S.T.
You are 100% correct!!!
S.T.
S.T.
If you want to run a wire across from the left fog light, obtain the miniture female connector and insert it into the one empty socket in the wireing harness plug on the right, you could energize the second filiments on both sides. But remember what scorchie said, you may draw too much current and blow a fuse, so do it at your own peril. As MB has pre-wired the right "fog light bulb" in the light assembly, I assume in some markets they illuminate both bulbs as rear fog lights and there is some way to do it safely. In the olden days MB over engineered cars and I would say that illuminating one extra bulb in a circuit would not cause a problem, but with these newer vehicles I am not so sure about this.
Now if you wanted to be 100% safe you could run a fused hot wire from your battery terminal to a relay you purchase from an auto supply store. Use the left fog light hot wire to energize the relay, and you would be sure not to over draw current on the circuit feeding the left rear fog light bulb. Use the switched side of the relay to power the second filiment of your right "rear fog light bulb".
Good luck.
2006 smart cdi
Thanks, sph17! I really like your relay idea!! I still have some time to contemplate this project before I can actually get to implement whatever I decide... Your relay idea is on the top tier so far.
Thanks again,
S.T.
Thanks again,
S.T.
FYI
The second filiment in the rear foglight bulb is 21 Watts which draws about 1.75 amps on a 12 volt system (actally 1.5V on automobile 14V systems).
I checked some of the fuses on my W123 (easy to get to, and the expanation card for what the fuses covered was self-expanitory), and figured how much current each fuse was passing. My 60W low beam was run though an 8A fuse and at 12V would pull 5A. The other low beam and two fog lights were run though a 16A fuse and pulled about 13A when all three lights are illuminated. It seems like with the older cars, MB figures in about 3A "reserve".
Although my first impression that another bulb wouldn't be that big a deal added to the circuit, another 1.75A draw if you only have 3A "extra" capacity on the circuit is getting too close to maxing out for me. The relay probably is the best way to go.
Good luck.
Good luck.
Re: FYI
So, doubling the draw would obviously exceed this rating.
I believe that in newer cars, there is a huge compromise on Mercedes' parts because everything needs to be engineered to last, but also the requirements of fuel economy and emissions drive a very aggressive weight reduction program. Thus, wiring is no longer larger than it needs to be. And the fibre optic cable that Mercedes uses for its telematics... it may seem cool, or we may think it sucks when it's time to add an aftermarket CD changer... but in reality, it lowers the weight of the car by 30-40 lbs.
-s-
And Even More
Another big no-no is putting in a higher rated fuse, when the correct fuse keeps blowing. It may "save" you from replacing the fuse again, but may cause a fire. You should realy figure out why the fuse is blowing.
The main wire coming out of the fuse is only as big as it needs to be. A wire feeding a 10A circuit is thiner than a wire feeding a 20A. If you put a 20A fuse into a 10A circuit, and that wire starts passing twice as much amperage as it was designed to do, it can heat up, melt the insulation and concievably cause a fire.
Fuses are your friends. They are designed to protect your car, Not infuriate you because they keep blowing when some electrical component starts drawing more current that it was designed to do (or because you added something that draws too much current).
cheers.
cheers.
