Ride Quality and Tire Wear
Has anyone installed an Eibach Sport Spring kit on their C280? I'm tempted to do it, as they're not too expensive, but the last thing I want is for the ride quality to be ruined, or for the tires to wear down excessively fast. I already have Bilstein sport shocks installed, so the ride is stiffer than stock as it is. As for the tires, I would think that as long as I dont have a lot of negative camber or anything they should be fine...yes?
1 Post
2008 SLK-280
Yes, it's made by K-Mac of Australia. It's 650 dollars just for the front or rear. Obviously it's not worth it because you could buy 4 sets of tires for a set of camber kits. Again, I don't have any inner tire wear. After 1700 miles all my tires have 9/32 of tread remaining all the way accross. The key to tire wear is make sure you have a good allignment, especially toe. And, rotate your tires every 5 thousand miles. I kept this up with my Kumho Supra 712's and got 32,000 miles out of them. That was a Z rated tire with a treadwear of 280.
