Alignment? Camber?
Old Aug 16, 2003 | 11:04 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Alignment? Camber?
Question about the rear wheels. When I was sitting at a restaurant looking outside at my car, I thought I saw my right rear wheel slanted!?! I must be going crazy I thought :p But, I think the rear wheels are suppose to be like this: |------|, right? Is it possible that it would be like this: /------| or |-------\ or even both being slanted in or out? Is this from normal wear and tear over the years and is this an easy problem to correct (cost and such) if it really is like that. Thanks for your help guys.
Old Aug 16, 2003 | 01:23 PM
C280 Jr.'s Avatar
95 C280
yes its slanted..i believe a mercedes cars come with 3 degree camber tilt, not fully sure hor much..but if you lower your car, it will tilt even more, like my car
Elvir
Old Aug 17, 2003 | 01:06 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
so it is normal for it to be a little slanted? I thought my camber was going nuts and f'd up and gonna cost me an arm and leg to fix....as long as it's normal. Why do they do that? Wouldn't there be uneven wear then for the tires?
Old Aug 17, 2003 | 01:13 AM
DougandhisC280's Avatar
2008 SLK-280
3 degrees??? You mean be able to be adjusted 3 degrees right? It should be about .6 degrees negative in the rear. Mine is 1.9 degrees negative but I don't feel like spending that much money on a camber kit.
Old Aug 17, 2003 | 01:15 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
so does this problem have to be corrected? if so, long term damages or just normal for w202's??
Old Aug 17, 2003 | 01:20 AM
2008 SLK-280
I don't think it's normal. Sounds like you need and allignment.
Old Aug 18, 2003 | 03:41 AM
mic280's Avatar
C280 & E320
You don't really need to spend that kind of money for a camber kit. Coz you'll need it for your new set of tires in no time.
Old Aug 18, 2003 | 03:44 AM
mic280's Avatar
C280 & E320
It can be corrected with a good reliable alignment shop.
Old Aug 18, 2003 | 01:41 PM
2008 SLK-280
Because of 1.9 degrees negative camber? Not likely.
