my tranny gasket gone?
Old 08-30-2003 | 05:49 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Hi all,
i was leaking some kind of oil or fluid onto my driveway. I noticed that it wasn't the engine because i didn't see any oil on the plastic cover at the bottom, so I assumed it was close by to the front. Looking at the underneathe of the car, I noticed that this thing, which looked like the tranny pan or something to do with the tranny is leaking...my dad says it's probably the gasket for which the fluid passes thru is cracked due to age of the car. Here's a pic...what's u'r take on it? I'm going back to dealership to get my bushings done soon, so might as well tell them about this. I'm assuming the gasket for this is inexpensive job? Thanks all.
Old 08-30-2003 | 08:41 PM
merclover's Avatar
1996 C220 (W202) and E320 (w210)
yep, it looks like the tranny gasket. although, i get the impression that it is very close tothe front axle, so it maybe a leak in the joints where the engine and tranny meet..
Old 08-30-2003 | 09:10 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
shouldn't be a costly job, eh? either one...i hear the tranny gasket isn't that costly, maybe $100?
Old 08-31-2003 | 07:34 PM
Steve Clark's Avatar
C32AMG
There is no gasket
between the engine and the gearbox where they join...it appears as though the front seal of your transmission is leaking.The seal itself is cheap- pulling the engine/gearbox to install it is not.
Old 08-31-2003 | 11:35 PM
merclover's Avatar
thats what i meant.. the front seal of the tranny.
Old 09-01-2003 | 11:46 PM
blackmercedes's Avatar
If you have the tranny out to reseal the front pump, do the rear main crankshaft seal at the same time.
Quick Reply: my tranny gasket gone?
