Condensation in Turn Signal
Old Aug 16, 2003 | 10:55 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
For some reason, I've had condensation in my front left turn signal housing for a few days now...can't seem to shake it out or anything. All the seals are tight and such...any suggestions? or should i just see if it drys out over time?
Old Aug 16, 2003 | 12:12 PM
DMXtremeZ's Avatar
2013 Audi S4
you probably have a crack in it... is it still the original?? but definitely a crack or a seal is out of place and water is seeping in....time for those new oem clear corners!!
Old Aug 16, 2003 | 12:14 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I'll check around...strange. My right one is not even clipped in (clip snapped or loose) and never got water in there...but i'll check. Looking for an opportunity to get clear corners...hehe. Where can I get good ones, ebay?
Old Aug 16, 2003 | 12:32 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
found this one on ebay...what u think? ratings for him for prior clear corners are good.
Old Aug 16, 2003 | 12:33 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
oops..forgot the link..hehe. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427804389
Old Aug 17, 2003 | 12:37 AM
DMXtremeZ's Avatar
2013 Audi S4
i wouldnt trust them... from stories of other members on this forum, the replica clear corners dont seal as well and lead to condensation within as well. so basically it would be a waste of money. just order a pair of OEM clear corners from bekkers.com.
Old Aug 31, 2003 | 11:47 AM
ricerokets4life's Avatar
whenever you get non-OEM lights, you should ALWAYS seal the edges and gaps with silicone. I would not take the chance of not doing that and looking retarded with condensation on the inside of the lights. Plus, you risk damaging the bulb and the connectors. I have clear corners on another car and I sealed those things completely with clear silicone. I have had them for 6 months and I've been through downpouring rains and ridiculous snows and they still haven't gotten condensation.
Old Aug 31, 2003 | 12:43 PM
DougandhisC280's Avatar
2008 SLK-280
It's not that they don't seal, they don't even fit.
Old Aug 31, 2003 | 05:14 PM
henry47's Avatar
asdf
hairblow dryer
Old Aug 31, 2003 | 05:15 PM
C230Kompressed's Avatar
I drive what I drive
hey cdawg, i bought my clear corners from that company. i had no condensation, nor a loose fit...but i do hear a lot of people saying that the right corner doesnt fit (clip in).. weird
Old Aug 31, 2003 | 10:46 PM
doug, the fit into the car affects whether or not water gets inside the light housing?
Old Sep 1, 2003 | 12:06 AM
henry47's Avatar
asdf
stop buying cheap stuff off e bay and buy the bosche ones or just keep your OEM corners.
Old Sep 1, 2003 | 12:11 AM
2008 SLK-280
Mine don't leak. They look good and fit right only after sanding and filing pieces down to make it fit. If you want clear corners learn from mine and everybody else's mistake and get Bosch.
Old Sep 1, 2003 | 10:36 PM
pks485's Avatar
Gdawg,
Have you tried using silicon caulk or some other sealant around your OEM corners yet? Maybe that might work. Otherwise, go for the bosch clear corners. With the silver paint on your car, it would look sweet!
Good Luck,
pks485
Old Sep 2, 2003 | 08:24 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
hmm...never thought of that...i'll give it a try when the damn rain stops here. thanks for the suggestion.
