Windows electrical problem
Your windows will then work on the first detent (manual up or down). Only once you press them in the fully up position till you hear a slight click will the auto-open or auto-up/auto-down features then work. You also need to cycle the vent part of the sunroof full open for a moment, again waiting for the slight click that indicates the system has learned the correct position.
Be prepared to input your radio code (in the owner's packet).
I have read where the right rear window motor + controller is the usual fault on this fully computerized system - but I have become skilled at resetting mine and I just accept that like any old computer, the W202 needs to be rebooted once in a while to maintain full operating condition.
I hope this information helps - and would you please post anything new you learn? There are five or so of us across several forums with similar problems.
