Check engine light reset
Old Nov 13, 2003 | 10:35 PM
amgmercedes's Avatar
My 93 E420's check engine light has come on, is there a way I can reset this myself before I pay the dealership to reset it for about $40?
It came on when I forgot to re-connect the sensor on the plastic cover behind the driver's side headlight after removing it to replace a bulb.
Old Nov 14, 2003 | 07:19 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Re: Check engine light reset
Disconnect the battery for about 1 minute and plug it back in. The light should go away when you start up again.
-G-
Old Nov 14, 2003 | 10:38 PM
Tried that already, even unplugged it for an entire day. Didnt work.
Thanks anyway.
Old Nov 14, 2003 | 11:11 PM
SLCPUNK's Avatar
I reset mine by taking off the neg battery cable. Or you can go to AZ and they'll reset it for free with their OBDII scanner. I pull codes there all the time for free.
Old Nov 18, 2003 | 02:17 AM
SLCPUNK's Avatar
oops. I see that it is a 1993 so obdII would be out of the question. Sorry.
