Inline Six
Old Jan 3, 2004 | 03:02 AM
IluvS500's Avatar
Jeep Grand Cherokee Overland
Inline Six
What year was the Inline Six phased out for the V-6 and what were the reasons?
Old Jan 3, 2004 | 03:21 AM
AREITU's Avatar
Mostly likely 1996.
For emissions, saftey and packaging.
Old Jan 3, 2004 | 04:54 AM
tpliquid's Avatar
too poor now
1997 was last year
Old Jan 3, 2004 | 04:22 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
v6 cheaper to make, smaller engine....
Old Jan 3, 2004 | 04:30 PM
woodie's Avatar
2003 CLK55AMG
I think the bore spacing on the new V8 and V6 are the same so they can use the same tooling on both blocks. Also on the 3-valve heads for each.
Old Jan 4, 2004 | 01:48 AM
DMXtremeZ's Avatar
2013 Audi S4
i like the inline better
Old Jan 4, 2004 | 06:23 PM
IluvS500's Avatar
The inline sounds cooler.
Old Jan 7, 2004 | 12:57 AM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
Don't know why they switched from the I6 to the V6. I know the I6 has 24 valves and the V6 has 18. The I6 is a higher reving engine as it cruises at higher RPM's than the V6, but that's prbably due to the electronc vs mechanical tranny.
Old Jan 7, 2004 | 10:06 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
They stopped the inlines and produced the V's because it was cheaper to make the V6's versus the Inline 6's.
-G-
Old Jan 7, 2004 | 01:02 PM
ABsC280's Avatar
1995 C280
any opinions on good vs. bad for the i6. also, any for the v6?
Old Jan 7, 2004 | 01:53 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
IMO, the I6 is a stronger and "bulletproof" engine. But prone to the headgastket problems in the earlier w202 years. Tho I think the V6 is more fuel efficient than the I6.
Also the harmonic balancer can go out of whack and cause headaches, but can't think of anything else right now.
-G-
Old Jan 7, 2004 | 01:54 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Check the tread below..
..For a detailed discussion of the pros-cons of the various combinations of I6, V6 4 spd transmission vs. 5 speed AT.
https://mbworld.org/forums/showthrea...threadid=56490
Old Jan 7, 2004 | 03:27 PM
ricerokets4life's Avatar
you should be wary of your MAF no matter what w202 you choose. they dont like many foriegn objects, including the oil from overoiled aftermarket air filters.
Old Jan 7, 2004 | 05:00 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
97 had the last i-6.
i-6's more balanced and will result for better weight distribution for the whole car. That's why BMW ain't giving up on their i-6, although it's pretty much to the end of how far they can go on power w/o force induction in the E46 M3's engine. I love the sound of the M3 I-6 too.
v-6's more efficient for fuel consumption, save a lot of space up front, but the weight is focused in one area. It's also less costly to built.
Old Jan 7, 2004 | 05:03 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Re: Check the tread below..
mnn...they were mainly talking about the M111 2.2 and 2.3 inline-4. only couple guys mentioned M112 inline6
Old Jan 7, 2004 | 06:02 PM
AREITU's Avatar
Actually the V6 is shorter so it's closer to the firewall for better weight dist. The I-6 is longer and hangs over the front. With a V6 You can also have a larger crumple zone and don't have to worry about the engine flying into the passengers when the car gets front-ended.
BMW's I-6s all sound good. The 325 sounds a bit sweeter than the 328/330 and the M3 sounds like a 325 with an overdose of steriods.
Old Jan 7, 2004 | 06:09 PM
vas2vas's Avatar
87 190E 2.6/1995 M3
that has nothing to do with safety, both bmw and m/b have collapsable engine mounts, so if the car has a front collision the engine is designed to slide underneath the car...
Old Jan 7, 2004 | 06:14 PM
AREITU's Avatar
Actually V6s can be placed closer to the firewall so provides better weight distribution. Fuel consumption isn't dependent on the cylinder arrangement, as my Accord V6 gets nearly the same gas mileage as my friend's BMW 325i, while the M3 gets jack for gas mileage.
Old Jan 8, 2004 | 04:55 AM
AREITU's Avatar
I wouldn't doubt that they're some of the safest cars on earth. One of the positive points regarding german over-engineering is that the saftey features are too. THe reason I mentioned V6s being potentially safer was a quip from "Car and Driver" mentioning a rumor that BMW was developing it's first V6 for various reasons, one being packaging.
Old Jan 8, 2004 | 05:06 PM
personally, i like the straight-6 better. i like the sound it makes at WOT.
