Puzzle: "Normal Fuel Trim" but got DTC 0170 and CEL is ON. Anyone ???
Old Mar 18, 2015 | 02:38 PM
MinkyuLee's Avatar
1997 c230
I have 1997 C230. It's been great with this car for 18 years and over 275k miles.
Recently the Check Engine Light (CEL) turned ON and I got the DTC code P0170, which is the error code for fuel trim bank 1. My OBD II readers displays the following STFT and LTFT numbers.
STFT B1 (%) 0.8
LTFT B1 (%) -0.8
Apparently, the number looks normal. And the car runs great.
But then why the CEL is ON and the error code? Any idea?
Thanks.
Mike
Old Mar 18, 2015 | 06:24 PM
cm60k's Avatar
Bad fuel pressure regulator/O2 sensors/catalytic converter,,
these could cause this CEL code, did you check any of them..?
ZAYED,,
Old Mar 26, 2015 | 04:46 PM
MinkyuLee's Avatar
1997 c230
ZAYED,,
Dear cm60k,
Thanks you for your suggestion. I checked the fuel pressure regulator and purge valve but it seems they are working fine.
Regarding the O2 sensor, can it go wrong without triggering a DTC code?
