odometer readout
Old Feb 14, 2004 | 04:12 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
odometer readout
My 2000 C280, purchased used, has an odometer issue: some of the lines that make up each digit don't light. So a 7 might actually be a 0 or9, and a 0 might be an 8 (follow?) The broker I bought it from said that MB's and BMW's are notorious for this, but I don't see any posts about it. Car only has 60K on it, any ideas?
Old Feb 14, 2004 | 04:33 PM
brett's Avatar
2004 e320
i see that all the time on cars that are rolled back on the odometer. if the digits go blank or one of the last digist illuminates dark red the odometer has been tampered with. PM me and i will let you know more-but i haven't heard of this as being chronic
Old Feb 15, 2004 | 01:01 AM
pointman's Avatar
a car that can't do the throttle reset.
i totally 100% agree...someone f-ed with the odometer.
Old Feb 15, 2004 | 07:35 AM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Re: odometer readout
On the BMW Forums, there is a common complaint of the pixels going out in the instrument cluster out of Warranty, especially the E39 (5 series). BMW is replacing them on a case by case basis, with the customer ususlly paying one hour of labor to the dealer. Some say it is a DYS job, with instrustions posted for how to. No one though has commeneted on the odometer not working as you describe, and I doubt that the cluster would be a DYS job if the odometer was included in the repair. Sounds like you are having smoke blown up your a** by your dealer/broker.
Did you do a CarFax check of your vehicle to see if it was Salvaged or registered with higher milage previously? If not, you should do it now, ASAP!
Old Feb 15, 2004 | 01:46 PM
eddieo45's Avatar
thanks sph, nothing bad on the carfax report, though I did find out it was a repo, not a returned 3 year lease as I had assumed. Imagine paying 3 years of payments on a brand new Benz and letting it get repo-ed?
Old Feb 15, 2004 | 02:38 PM
redcoupe's Avatar
11 ML350
You can't roll back the odometer on a digital dash.
Old Feb 15, 2004 | 04:25 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
I'm sure you can hook up a computer and fiddle with it to change it somehow...as it's the same when you replace the cluster, the dealer just hooks up a computer to the cluster pin's in the back of it and changes the readout.
Old Feb 15, 2004 | 04:44 PM
redcoupe's Avatar
11 ML350
NO, the dealer does not hook up hook up a computer to the pins.
Need to get you stuff straight.
The dealer hooks up what we call a SDS machine.
From there I can go into the old cluster and download the information for thecluster int he SDS machine.(the information that is download has to do with setting and thing that pertain to the cluster, no the miles.)
When I order a cluster for your car, it is sent to me with the miles already uploaded into it. On newer cluster I can only raise the miles, not lower them.
Brian(MB TECH)
Old Feb 15, 2004 | 04:49 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Brian(MB TECH)
Whoa....calm down there. I only relayed what I was told.
GDawgC220's Avatar
'05 A4 1.8TQM6
Brian(MB TECH)
GDawgC220's Avatar
'05 A4 1.8TQM6
Brian(MB TECH)
GDawgC220's Avatar
'05 A4 1.8TQM6
Brian(MB TECH)
Old Feb 15, 2004 | 04:50 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Brian(MB TECH)
redcoupe's Avatar
11 ML350
Double post
Its ok I just hate when people are feed the wrong info.
Now you know
Brian
Old Feb 15, 2004 | 04:51 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
sorry for the reposts...server timed out a few times but apparently went thru
Old Feb 15, 2004 | 07:35 PM
sph17's Avatar
Odometers in Europe
I thought someone a few months ago said MB Dealers (and others) in Europe could "adjust" Odometers with a frequency generator. Am I mistaken about this?
