error code resets & the battery
Old Feb 15, 2004 | 03:48 PM
c280driver's Avatar
1997 C280 Automatic
If my car goes into a "limp mode" because of an error code, can I reset the system by taking the battery offline?
If this resets the error code, would I then get out of "limp mode"?
Thanks in advance.
Old Feb 15, 2004 | 04:24 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Pretty much when you take out the battery, it resets everything in the car, including the ECU. So my guess is that it will reset that error code too. Worth a shot.
Old Feb 15, 2004 | 06:25 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Re: error code resets & the battery
Thanks in advance.
My experience with limp-home-mode is that turning off the car re-set the computer, and it went back to normal operation until the next time a major fault kicked it into LHM again. The CEL came on and stayed on until re-set by the dealer.
Old Feb 15, 2004 | 11:57 PM
c280driver's Avatar
1997 C280 Automatic
I tried this
I did turn the car off and the limp mode only got worse.
Old Feb 16, 2004 | 12:00 AM
c280driver's Avatar
1997 C280 Automatic
what do you think?...
What is your opinion on this...if the car seems to run fine normally and then all of a sudden something happens that puts it into limp mode, is taking the battery off-line to reset the code and have the car drive normally a valid option?
I am considering doing this because the car seems to be running fine for a couple of thousand miles and then all of a sudden...limp.
Taking the battery off-line seems like a cheap alternative to having to buy an expensive diagnostic/code reader/reset tool.
What do you think?
Old Feb 16, 2004 | 09:37 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
Sometimes computers can act weird and throw a code once in a rare while....but disconnecting the battery isn't bad. Its just a hassel to reset the clocks and input your security code for the radio. But most of the time it does clear the computer and then gives you a chance to see if there really is an error and if there is, it will come back in a day or two.
Old Feb 18, 2004 | 12:05 AM
c280driver's Avatar
1997 C280 Automatic
If I were to do this...
If I were to disconnect the battery, do I have to reset the car's computer at all or will it work fine but I'll just have to reset the clock and radio?
Old Feb 18, 2004 | 02:34 AM
DougandhisC280's Avatar
2008 SLK-280
My money is going on the MAS meter. I've had 3 in the last 2 years. Only once has the check engine light come on.
Oh, and when I put money on the MAS meter, it is always the MAS meter.
Old Feb 18, 2004 | 08:38 AM
c280driver's Avatar
1997 C280 Automatic
I just had the MAF Sensor replaced with new OEM. I don't think that's the problem. The error code is pointing to a valve body issue...
Old Feb 19, 2004 | 03:01 PM
meanie's Avatar
What was the code # ?
