Door will not stayed closed or latch C230 (W202)
Using a screwdriver I played with the latch mechanism by pushing on the latch to simulate the door closing and the latch moves like it should...as compared with the passenger side which works. No clue what the problem is but I sprayed the mechanism with lubricant to see if that solved the problem but it does not.
Is there something broken, need an adjustment?
If you decide to loosen and adjust the striker plate (assuming it's adjustable on the 202, mine is not), keep in mind that the bolts are quite soft and may be well stuck on, so there's a danger of rounding them.
Does anyone know how difficult it is to change out this part?...or are there instructions somewhere?
