ATE Power Disc
Old Apr 26, 2004 | 09:53 PM
JIC280's Avatar
1995 C280
Thumbs down ATE Power Disc
Hey guys, im a newbie. I own a 1995 C280. I just put on a new set of ATE power disc front rotors and new OEM MB pads for the front. Ive been using it for about 2 months now and now, the brakes are pure CRAP. Whenever I brake lightly, it makes this grinding squeaking annoying sound. ATE Power Disc SUCK! I knew i should have just done an OEM set up now i have to buy new rotors again. What is the OEM front and rear rotors? Is it BALO? Thanks
Old Apr 26, 2004 | 11:05 PM
meanie's Avatar
FYI, Ate Powerdiscs are some of the best rotors you can buy.
Just because you fu.....ed up on the installation, don't blame it on the parts.
Old Apr 26, 2004 | 11:26 PM
JIC280's Avatar
1995 C280
I dont think I FU@#$%$ up on the install man, its not too hard to to put on rotors, just take off the set screw and put the new rotor and set screw back on and thats exactly what I did. Unless............
Old Apr 26, 2004 | 11:56 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
ATE sucks holy hog ***. Never buy them, get Brembro or Zimms. As a rule, dealer pads are made by them too...sucky. Try Pagid or Remza next time, anti-squeal is already bonded to the back of the pad. Great feel, great cold-bite etc. For now, try re-bedding them, stopping HARD 3x from speed. You probally need to camber the edges of the pads with a file. Not worth it when Remzas are so cheap. I'd replace the pads and keep the rotors, even though they >SUCK<!
Old Apr 27, 2004 | 11:21 AM
vas2vas's Avatar
87 190E 2.6/1995 M3
I put ate power disks with OEM pagid pads and I have no grinding noises to report, just really good stopping power...
about the install... did you clean the rotors before installation?
did you use the special anti squeeck lubricant when installing the pads?... sometimes it can make all the difference...
Old Apr 27, 2004 | 08:06 PM
It's the pads squealing, not the rotors. ATE rotors now have dressing the does not need to be wiped off, although I would wipe them down. Pagids are great pads, I'm not even interested in trying any new ones.
Old Apr 29, 2004 | 03:49 PM
timecop369's Avatar
1999 C280 Sport
I will try the ATE discs
I just ordered the the ATE power discs along w/ PBR deluxe pads for the gf's 2000 BMW 323i. Will put it on this weekend and let you know if it squeaks.
It will be installed by my brother at his shop, so no excuses for if you did it right or put the anti-squeaking gel.
I'll keep you posted. I was thinking of getting the same setup for my '99 C280 so will be doing my own roadside test.
timecop369
Old Apr 30, 2004 | 12:38 PM
pluggers's Avatar
1995 C200 Sport, Remus Muffler,illuminated door sills,clear corners
I have ATE rotors on mine for about 4 months,and I can say I get the same grinding noise from mine useing the pads that I got when ordering the rotors,Feels like your using bricks instead of pads too stop the car.In the wet theres no problems only get it when its dry slowing up for junctions.Going OEM when I can afford.
Old Apr 30, 2004 | 01:11 PM
megabyting's Avatar
I had the same problem for my volvo. You may need to file the edge of the pads.
Old May 3, 2004 | 03:41 AM
timecop369's Avatar
1999 C280 Sport
Thumbs up so far so good...
I put the ATE power discs and PBR deluxe pads on this morning on the gf's 2000 BMW 323i (4/2/04) and so far so good. Not much grinding noise.
I wanted the same setup for the rear but doesn't seem like the have the ATE power discs. Just the regular ATE discs.
It'll be a couple weeks to find the true affects and brake dust result.
Old May 3, 2004 | 12:33 PM
pluggers's Avatar
Tryed this on mine over the weekend and its definatly improved,No more grinding noise when braking,Shall have too see how long it is before the pads need fileing again,
Old May 6, 2004 | 02:58 PM
DougandhisC280's Avatar
2008 SLK-280
I have Ate Power Discs and PBR Deluxe pads and it's the best, smoothest brake combination I've ever tried. And I've tried EVERYTHING!
Old May 6, 2004 | 04:01 PM
meanie's Avatar
Amen to that!
Too bad there is always some jerk shooting off his mouth, without having a clue.
Old May 6, 2004 | 06:25 PM
timecop369's Avatar
1999 C280 Sport
It's been smooth sailing so far (5-days)... No noise and no OEM brake dust.
Doug... I got these disc and pads based on your recommendations in the archives.... THANKS! Just got regular ATE discs and PBR deluxe pads for the rear... those will be put on Friday.
And will probably be my next setup on the '99 C280.
timecop369
Old May 6, 2004 | 08:21 PM
2008 SLK-280
Glad to hear it! Let us know how it goes.
