Head Unit Adaptor Question
i posted it in the audio/elec forum, but no answers...
In a 1998 c-280...
right now it's all stock in there...
i do have the bose amp in case it matters -
was curious as to WHICH "kit" or "adaptor" i use/buy to give to the shop that's installing it... i heard that the aftermarket (alpine or whatever) stereos sound like trash and there's a hum from all the speakers if u just try and connect... i just wanna be sure because i dont wanna get my car back from the idiots and have it sound like trash. it's no masterpiece or anything, i just wanted some info - and i searched and searched in both here and the w202 forum but can't find that thread. i 'member someone talkin about using a VW or Audi adaptor... this true??
let me know, someone, pleeease?
and let me thank u ahead of time toooooo ...
sol
thank u - and i miss u all and hope ur all doing beautifully . .. .
*again, thanks*
If your going aftermarket deck, what you need is a VW/Audi dash kit, european antenna adapter and a VW/Audi wiring harness/adapter to plug and play with the old wiring from the deck.
Simple installation, good luck!
I don't think you could even try and just connect the stock wiring to the aftermarket connector, different pin layout I believe. The adapter is cheap, like $10.
I've had my deck in for 2 years now, sounds great
What you need is a VW/Audi wiring harness, european antenna adapter (to work with the aftermarket antenna socket) and a VW/Audi dash kit.
There's some people who say you need a signal adjuster or something like that also. Did you have to get anything like the GDawg or can it be done with just a wiring adapter? I REALLY wouldn't mind being able to hook up my Sony deck that I bought a year ago in my 95 C 280.
Benz916 - That is true, they don't make a harness for MB, which is why the VW/Audi one is needed. That one plugs and plays with the factory MB harness, just have to connect them up, wire for wire and it'll be fine.
https://mbworld.org/forums/showthrea...t=audi+adaptor
I think this guy didn't use a dash kit. Hit me back guys...soon. I am taking it in tomorrow.
thanks guys - i realllllllly APPRECIATE ALLLLL YOUR HELP - and mr. rice rockets for life!!! whatsup brotha - good to see u as well... i just got back and read this - i sooo appreciate the responses and the helps <3 i love you guys and hope u all had the most beautiful weekend
sol
I'm assuming the '98 non bose setup is the same wiring as the '94 non bose setup.
quick question though GDAWG - i am pretty sure i do have the bose amp setup - is this gonna be any different - or do i just get those 3 components:
1. the adaptor for the antenna (euro)
2. the vw/audi plug/play wiring harness adaptor
3. the dash kit
thanks soooo much again and sorry if this is a knucklehead question. . . appreciate allll your help.
much love
and happy mothas day to any mothas out there
regardless, you do need those three components to set in the new deck to make it work, but with the BOSE system, there's a factory BOSE amp in the right rear of the trunk, behind the liner i believe. You need a component to bypass that amp or you may get bad sound out of the speakers (what someone told me)...but I forgot what you need to bypass the amp.
I think someone on this forum has done the BOSE bypass....see if you can find it in the old posts?
