No Split Rear Seat: Can I Wire A System?
Basically, look behind the trunk lining and you'll see some wiring running into the side there. That's where it runs along the back door curve into the underside of the door sills. You have to have someone pulling the side cushion in towards the cabin so that you can expose the wiring area to get it through, one man probably won't be enough to get the wiring through cuz it's TIGHT space in there.
Good luck!
