How to remove gauge cluster on W202???
Old May 15, 2004 | 01:29 AM
Leandro's Avatar
CLK430, CLK320 Cabriolet, ML350
Someone please tell me how to remove gauge cluster on a 1994 C220? Or provide me a link with a "how to." Thanks!
Old May 15, 2004 | 03:50 AM
pointman's Avatar
a car that can't do the throttle reset.
"search" button.
Old May 15, 2004 | 09:16 AM
Leandro's Avatar
Originally posted by ahopeter
"search" button.
"search" button gets "nothing"
Old May 15, 2004 | 11:43 AM
vas2vas's Avatar
87 190E 2.6/1995 M3
you need a set of special tools (cluster hooks), you slide them on each side, twist to latch on and firmly pull out... at least one member made his own tools, but generally you can get them from a dealer p/n: 140 589 02 33 00 cost I think is under $20.
Old May 16, 2004 | 12:26 AM
DougandhisC280's Avatar
2008 SLK-280
or use a couple allen wrenches. Slide them in the top about 2 inches from the side, turn them enough so they catch on and pull. It's nothing too difficult.
Old May 16, 2004 | 01:55 AM
SLCPUNK's Avatar
I need to just clean my needles because they are sticking.
Could I just pull it out enough to take the front plastic off ?
Or am I going to have to remove the entire unit to get to the needles?
Thanks.
Old May 16, 2004 | 04:55 AM
2008 SLK-280
Not sure, I've never gone that far. Pull it out and take a look. Let me know how it goes because my needles stick too. I just figure it'll be a good excuse if I get pulled over.
Old May 16, 2004 | 12:45 PM
Leandro's Avatar
This has been great advise. Just what i was looking for. I would like to ask though, this "pulling out" will remove the gauge pod cluster (like I would lke to do) or is it to remove the glass that covers the gauges in the gauge pod cluster?
Old May 16, 2004 | 01:27 PM
pointman's Avatar
entire cluster.
Old May 16, 2004 | 02:47 PM
SLCPUNK's Avatar
Can I just pull it out enough to remove the pastic cover?
Without removing it all the way.
Old May 16, 2004 | 04:33 PM
Leandro's Avatar
Hey you guys thanks for the directions! I just did it and it was so easy. I did it the poor man's way too and used allen wrench (as recommended above) instead of getting the pulling hooks from dealer. Just as a tip, use a pair of pliers to grip the allen wrenches when you pull for a better grip than you could do with your hands. Anyway, it came right out, like you guys said it would. Thanks!!!!
Old May 16, 2004 | 04:46 PM
SLCPUNK's Avatar
Why did you have to take it out anyway?
Did you have to disconnect anything fromt he transmisison first or no?
Old May 16, 2004 | 05:32 PM
SLCPUNK's Avatar
OK I used a coat hanger and made my own hooks. It took me all of 2 minutes to get the cluster out.
Now...can somebody please tell me how to get this clear plastic cover off (so I don't break it trying) to clean the needles?
I'd really appreciate it.
Old May 17, 2004 | 12:22 AM
pointman's Avatar
i smell odometer roll back.
Old May 17, 2004 | 02:05 AM
SLCPUNK's Avatar
So.........now that the original poster has taken his cluster out, could you kindly share with us how to get that lense cover off?
Just think...you could help somebody who needs it!
Old May 17, 2004 | 03:51 AM
Leandro's Avatar
I didnt see how to remove lense. I just dealt with an electrical issue behind the pod. I wish I paid attention as to how to remove the lense so I could offer advice. Sorry!
Old Feb 18, 2011 | 12:15 AM
dreamfootage's Avatar
1994 C220 MERC
HELLO,
NEW HERE.
DO U HAVE TO REMOVE THE STEERING TO GET THE CLUSTER OFF..?
Old Feb 18, 2011 | 12:24 PM
Capt's Avatar
2000 C280 Sport
If you have a telescopic steering column then you don't need to remove the steering wheel. If not, it is possible to remove the cluster without taking off the sttering wheel but you will have to do some wiggling to get it out. This could be a risky option as you might scratch the cluster lens. My advice would be to remove the steering wheel.
