my c180 1994 w202 is misfiring .
To start....
Did you check your MAF sensor?
May just need to be cleaned with a MAF cleaner. I use CRC brand.
Common problem on the C series among others.
See/feel how it runs after the cleaning and monitor. If persists, then swap it out.
If you see oil in MAF, recommend you to change out your PCV Valve too and Oil Separator as well.
You didnt mention any error codes...
