oil change help???
95 c280
oil change help???
i just recently bought a w202. all my previous cars i have done my own oil changes on and they have been easy. looking at my c280 it doesn't look so easy. wheres the drain plug? wheres the oil filter? does anyone have any directions or hints on changing my oil in a 95 c280? thanks
'05 A4 1.8TQM6
most people use a suction device made by "griots" (do a search). What you do is stick the tube down the dipstick tube and it sucks up the oil.
the oil filter housing is in the front, to the right of the engine block as your looking at it. it's a small cylindrical shaped object. You need a special MB tool to remove the cap...check out your local MB parts dept...cheap tool, I think around $10?
by using the suction, it's much easier than lifting the car up on jacks or whatnot.
1996 C36
If you drop the engine undertray you will see the drain nut towards the front on the driver's side of the pan. On the 104 motor the oil filter is on the driver's side of the motor near the firewall and the Mercedes filter tool will make your life much eaiser. The engine holds quite a bit of oil so make sure you have a drain pan that is large enough.
1995 C280
i just brought mine in to the dealership for an oil change. it's $50, but you get a tank of gas from their loaner, and the price of oil, filter, gas and time, and a car wash, i think it's worth it. but for you d.i.y. guys i'm sure you'd rather just d.i.y.
95 c280
ya i did the oil change today peice of cake easiest one i have ever done. the drain plug came right off and the filter came off just by twisting with my hand. it was tight but not so tight that i needed a tool. on club202 there was picture and **** of where to find the plug and filter. but thanks for the help
