1995 C280 - Headlight Switch Replacement
Old Dec 8, 2018 | 09:51 AM
RPB's Avatar
RPB
Hey Guys,
Does anyone happen to have the diy procedure for the headlight switch replacement? I believe the lower dash panel needs to be removed. It seems like a bit of a pain to remove on the earlier 202 models.
Any insight would be appreciated!
Cheers,
-Rob
Old Dec 8, 2018 | 05:09 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Not sure for the specific year 1995, however it should be similar to 97s and up to 2000 for the w202s.
Also, please fill-in your user CP info.
Old Dec 8, 2018 | 07:08 PM
RPB's Avatar
RPB
Thx! The procedure appears to be quite a bit more labor intensive than the later yrs.
I found a diy clip for removing the lower driver panel on my yr:
Cheers.
Old Dec 8, 2018 | 07:46 PM
khomer2's Avatar
I watched this video - slightly more involved with your earlier model (having more steps to remove the d/s under dash panel)
Once that is off, you're off to the races to getting access and removal of the headlight switch.
Old Dec 12, 2018 | 07:57 AM
RPB's Avatar
RPB
Should go smoothly w/ the help of the clip, it goes to show how tightly they built the early gen models.
Thx again!
