230 kompressor
Old Jun 27, 2019 | 01:53 PM
ihkllass's Avatar
c230 compressor 202 engine
230 kompressor
engine difficult to start , when it starts engine unstable two injectors shuts other times one injector shuts please help me find solution
Old Jun 27, 2019 | 08:50 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Welcome ihkllass,
scan and post your error codes.
Please update the year of your w202
Old Jun 28, 2019 | 10:55 AM
ihkllass's Avatar
c230 kompressor
Originally Posted by khomer2
Welcome ihkllass,
C
2000 year model
error code B1421
Last edited by ihkllass; Jun 28, 2019 at 11:09 AM. Reason: Sorry the model year is 2000
Old Jun 28, 2019 | 11:08 AM
ihkllass's Avatar
Old Jun 28, 2019 | 04:12 PM
khomer2's Avatar
C
2000 year model
error code B1421
This has to do with your AC. You need to run an AC diagnostics.
Erase the error code and see if it returns the next time you run the diagnostics.
As for your difficult starting issues, scan again to see what saved codes show up.
btw, this B1421 has nothing to do with your starting issues.
Old Jul 3, 2019 | 09:09 AM
ihkllass's Avatar
c230 kompressor
Error code p0450 I also need radio code please help
Old Jul 3, 2019 | 12:14 PM
khomer2's Avatar
Scan and erase the saved codes. Drive around and see if it comes up again.
P0450 - could be your gas cap not sealing correctly (due to age).
Pick up an OEM part (no generic caps) to replace it.
Radio code? call your local stealership with either your vin# (if it's the origianl oem radio) or provide them with the serial # of the oem radio (need to remove it to read the #)
Old Jul 4, 2019 | 04:02 PM
ihkllass's Avatar
Hello
thanks for your good advice the car is up and running
it does not have quick start. check engine light went off, comes back after a strange noise coming from the fuel pump please help .
Old Jul 4, 2019 | 04:12 PM
khomer2's Avatar
Hello
CEL on and off again.
Scan again and post the saved codes.
How do you know the noise is coming from the fuel pump?
