W202 windows problem
my passenger windows suddenly when I try to up or done stopped many times in it is way UP or down
all the others works perfect. I remove the battery to rest it.
it works fine only once full up and full down without any stops. then it return back. I reset it again but it is still has the problem
I remove the windows switch and I clean it also by dry electronic cleaner.
did an one know how to fix?
Procedure - Press the up button until the window is fully closed and hold it for 2 seconds (for each window)
Is this how you reset it?
I BELIEVE YOUR PULLING THE BUTTON ALL THE WAY UP AND IF SO THE WINDOW WILL STOP IF IT IS IN RESET MODE.
