B-Service for 1998 C280 with ~65k miles
Subscribe
May 9, 2002 | 03:51 PM
What all is included in the B-Service? How can I reset the little tool wrench light? The dealer wants $380 for this service and they said it includes rotate and balance tires (which I'm getting done at NTB for free), air condition filter (I could use a tech. write up for this if one is available), oil & filter (no problem), new wiper inserts (really no problem), and fuel system cleaner (I have red line fuel system cleaner, any other recommendations? Do I have to change the spark plugs or anything after running this stuff?).
Reply 0
May 11, 2002 | 01:03 AM
If out of warranty never go back to the dealer for maintenance service. I could do all that myself for about $50. Then again if you are going to sell the car records may be important to you. Just my $.02
Reply 0
May 11, 2002 | 10:20 AM
I picked up the parts for a little under $60. I could use a tip on how to change the hvac (dust/ac) filter. Anyone know how? Thanks.
MBKid, I'm not too concerned with records. Thanks though.
Reply 0
May 12, 2002 | 12:26 AM
First thing you have to do is remove the black footwell vent on the passenger side, located on the transmission tunnel just under the dash. To remove it, turn the Phillips-head screw 90 degrees counter-clockwise and no more. It's not a screw, just a retainer. Once you've removed that piece, take the underdash panel off by removing the three Phillips screws that hold it on. Notice the tab on the panel towards the rear, it needs to fit into it's slot upon reinstallation. With that out of the way, you'll see a rectangular-shaped black piece with two white sliding retainers. Slide the retainers to each end of the rectangular piece, and remove the piece. The filter just pulls out, although it's easier to remove the rearward end first.
Reply 0
May 13, 2002 | 04:05 PM
Thanks again mbtech208, I appreciate your help.
Reply 0
Subscribe
Currently Active Users (1)
