Failed brake lights
Old Sep 16, 2021 | 09:56 PM
mikelspoon's Avatar
1994 C280
Failed brake lights
Failed brake lights.
I have a 1994 C280, recently purchased and my first Mercedes. I had been sitting for 6 years. I have it running after a bit of fuel system work and parts replacement. Getting it ready to legally drive when I noticed I had no brake lights. I went to the fuse box under the hood and checked all fuses. Pulled them all, cleaned them and checked them, none were bad,. I back fed the brake light circuit from the trunk and all brake lights lit. Next stop was under the dash to the brake light switch. There are two plugs (connectors) on the switch. The small plug has power on one side, the larger one has a multi-wire plug piggybacked on a two wire plug to the switch. Now power here. I am lost as the fuse is good, the switch is good(replaced with OEM today). Where does the brake light switch get it's power. Yes, I had the ignition turned on. Any and all help would be appreciated.
Old Feb 13, 2022 | 05:35 PM
ihaveaquestion's Avatar
2000 C230 Kompressor
Did you find out what was wrong with the brake lights? I am having trouble with the right rear brake light. Tbe bulbs low beam works fine but the high beam (while braking) doesn't come on (only the right rear, the left rear works fine). So far, I have replaced the lamp carrier, brake light switch, and checked all the fuses. Any help/suggestion?
