tranny fluid change
1 Post
06 Granite Grey c230
Originally Posted by Benz916
the dealer told me $200-225 to change the tranny fluid in my 1998 c230. Is that pretty good or?
give or take
but sounds fair.
sanny
I see....well i just wanted to change it because I wouldnt feel right waiting til 100k to change it. It is at 62k or so...and I think every 60k sounds good.
1 Post
absc280, you have a 1995 right...your tranny is different than mine. Mine is much more drama.
6/98 seems to ring a bell in my head as the date they changed the tranny.
sanny
Well..i dont know much about it...but the 97 and up the newer kind of tranny...with no dipstick....what do you mean 6/98...did they revise something at that time to these trannys?
KOMPRESSOR
I've got a 99 with the new transmission, local Mercedes Authorized Shop says $185.00 for a transmisson oil change. The owner says that the dealer recomends a transmission change? Does the dealer really recomend a tranny change at 60K...that is a little extreme isn't it?
1 Post
i ithnk 60k sounds right i am going to spend about 120 in parts so i ithnk oil, filter, dipstick, seals...
so 185 is not too bad of a deal...
i am at 61k and im gonna def do the tran oil soon.
sanny
sanny
'05 A4 1.8TQM6
since MB came out with the electronic trannys, supposedly it's 'sealed' and the fluid cannot be changed. MB says it's 'lifetime'...but if you have a mechanic pull the fluid out at about 70k, you'll see it's all brown and metal shavings everywhere. My independent MB dealer recommends once every ~70k miles (they're pretty knowledgeble people)
If you ask a MB dealer, 99% won't touch the electronic tranny's with the 'lifetime fill fluid'.
Most of the time, you'll have to go to a MB independent place, which there mechanics know that the fluid needs changing (which most independent places recommend ~70k miles)
the synthetic AT fluid is expensive, about $9 / quart and it takes quite a bit from what I've read and heard (10-11 quarts) then labor and parts so it can run about $200-$250 for the AT fluid change alone. But worth it to do AT LEAST once at 70k or so to refresh the tranny.
the older trannys (pre-97/98) are mechanical so changes on those are pretty straight forward and less costly. There are actually dipsticks in the engine bay to check and such.
The newer one's don't have a tranny dipstick with the car...but here's the kicker...MB says it's 'LIFETIME' fluid but then why do they sell the dipstick for newer models at the dealerships???
HTH
HTH
99 C230 Kompressor
My 99 C230k just hit 100K and I went to a MB specialist and I ask him about the tranny service and he told me it was going to cost $250 to change the fluid. And then he told me that my car uses a different type of tranny fluid than the older models. But anyways Im just going to do the service myself I have done it before when I was in Autotech in a few cars including luxury cars. Is not really hard to change the filter and the fluid is just a messy job. Does any one know how much the kit for the filter and the fluid??
'05 A4 1.8TQM6
Then you need the tranny dipstick (and the fluid has to be put in at a specific temperature i believe). In the long run, you saving on labor...parts are about the same if the mechanic did it. It may be worth it to get it done at the MB specialist or if you like to get a lil messy, DIY.
But all the parts you can get at your local MB parts counter
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
It can be argued that the dipstick is for refilling the transmission, which would be required if ANY work is done on the transmission (replacing any seals, the control unit, bands, etc.), which is a problem that could happen whether it was designed to be replaced or not (for instance, an oil pan seal in an engine is designed to last the the life of the engine, but rarely does).
-s-
'05 A4 1.8TQM6
Originally Posted by scorchie
That's not a good argument.
-s-
-s-
In Model Year 1997, MB made the 722.6 (in various forms) standard on all North American sold cars. The 722.6 is a five speed automatic that has nothing in common with the 722.4 four speed, and not even the 722.5 five speed.
The transmission is an electronic unit that uses a "fill for life" fluid that is not sold anywhere but at an MB dealer. Even Mercedes has no definition of what the term "life" means. Some techs feel that changing the fluid every 60K-miles is prudent, others got to 100K-miles, and some say to go with MB and never change it.
One thing that is clear is that the tranny is VERY sensitive to fluid level, and Mercedes is sick of trans problems caused by "topping off" the fluid, like quick-lube shops do. That will cut the life of your tranny dramatically. So, the 722.6 has no dipstick. When changing the 722.6 fluid and filter, it's important to use the SDS to set the sluid with the trans fluid at EXACTLY 80C. If not, the fluid level will be incorrect, and you will compromise the longevity of the trans.
Keep in mind that replacing a 722.6 can run $5K, perhaps more. For the savings of $150 in labour, I would not take a chance on ruining a $5K piece of equipment.
