'99 C230K EGR Frustration, P0440 Code
P0440 is generally related to the evaporative canister - reported by a pressure sensor associated with fuel tank evaporative system. Generally it means there is a leak in the fuel vapor system - can be a hose, fuel cap, fuel fill line, even the canister itself if folks overfilled the tank too many times. So so on. The pressure sensor itself can be bad or blocked or have a poor connector. If you look at the EPC/WIS you can follow the lines that need to be tested. I myself have been lucky and we have not had to track down a 0440 code on our 230k. You referred to a "he" above, I'm assuming you have a friend helping you out.
It appears that you need someone that can help properly diagnose this. Searching around I found these:
German Auto Repair in Watertown. https://germanautorepairllc.com/mercedes-repair/
Roggi's Auto in Hartford https://www.roggisauto.com/mercedes-repair-service/
That said these cars are getting old and replacing of most of the hoses is just a fact of life. It is so easy for a minor crack on the back side that you can't see in a hose to affect many things related to emissions.
Let us know how it turned out.
