W202 engine swap to m111.983
Old Nov 1, 2023 | 12:24 PM
Oskars644's Avatar
W202
Hello.
I would apriciate some info.
Basicly had a donor slk(r170) with 2.3kompressor engine 145kw. On an auto transmition. I swaped the engine in a w202 1994. Got the immo working the car now starts and drives but it doesent have the transmition ecu and combinated module now drives with a 5spd manual box and single mass fly wheel remade to tak a 240mm clutch. My biggest problem now is 3k limitter. Tried to do coding with launch it has all the options but doesent save anything. Ecu is Sim4LE is paired with the original immo from slk. What do i do any ideas? I heard that you can only code when virginizing immo.?
Old Dec 12, 2023 | 12:49 PM
kamran piroozi's Avatar
w210
Thumbs up changing engine m111 any type
[QUOTE=Oskars644;8869996]Hello.
Hi dear friend
If the factory engine of your car is 111, you can use 111 983 along with ecm & tcm of 202 car.
Otherwise, you must get the ecm tcm of the new engine.
Old Jan 23, 2024 | 04:03 AM
Oskars644's Avatar
W202
Swap is finaly
completed been driving now for a month everything works perfectly. Have a few upgrades for the engine aswell. For any info just ask.
