Can't go above 3500rpm. Fells like a RPM limiter.
Old Jul 26, 2024 | 09:12 AM
step2040's Avatar
W202
Can't go above 3500rpm. Feel’s like a RPM limiter.
Hi. I need some help. I'm working on a W202 220C (gasoline) from 1995.
I can't go above 3500rpm. MAF sensor replaced. Lamda sonde replaced. Fuel filter replaced. Spark plugs replaced.
It kinda feel's like there's a speed/rpm limiter.
There's a single fault code. "Lamda regulation, out of reach". That's why i changed the sensor.
Any idea's?
Old Aug 9, 2024 | 12:45 PM
Xouras's Avatar
Mercedes w202 1995
I had the same issue with w202 c180 1995 but stoped
at 4000rpm. I change the red fuse (you can see it at attached IMAGE) and after that all worked fine.
Old Aug 12, 2024 | 04:24 AM
step2040's Avatar
W202
Were the fuse blown? Cause my fuse is not?
Old Aug 13, 2024 | 10:03 AM
Xouras's Avatar
Mercedes w202 1995
Yes was blown for some reason.
When car is stopped without gear then max rpm cannot be more from 4000 (safety reasons) and this depend from speedometer .Perhaps there is the problem, cannot read the speedometer (e.g. faulty wiring).
Good luck on this.
