need suspension help
Old Nov 24, 2004 | 06:57 AM
Benz916's Avatar
1998 C230
I know this has been beaten up in the forums...but im lazy.
Here is a pic of my car...the car is way too high and needs to be lowered. I dont want to lower the car much. What springs give the best ride(closest to stock)? Will I need a camber kit? Right now the rear is lower than the front, but i want the front to be lower than the rear as well. I plan on only changin the springs. I basically want to give it a sport look and not a slammed look.
Old Nov 24, 2004 | 06:58 AM
Benz916's Avatar
1998 C230
Old Nov 24, 2004 | 06:59 AM
Benz916's Avatar
1998 C230
For some reason I cant get the pic too come up. I'll see what i can do tomorrow.
Old Nov 24, 2004 | 07:03 AM
Benz916's Avatar
1998 C230
I think i got it. 18 inch wheels fyi.
Old Nov 24, 2004 | 10:40 AM
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
Maybe it's the pic, but I think your ride height looks fine the way it is.
Old Nov 24, 2004 | 03:55 PM
KWiK's Avatar
2002 C230 : 2007 C230
order yourself some Vogtland springs and enjoy...
Old Nov 24, 2004 | 04:07 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
I'd just replace the pads. Cheapest way to go and you won't need to do anything else (IMO).
Old Nov 24, 2004 | 06:07 PM
Benz916's Avatar
1998 C230
how much would the pads really lower it..it may not be enough?
Old Nov 24, 2004 | 07:22 PM
trbo2nr's Avatar
The largest pad is 17mm and the smallest is 9mm. I have 17mm on the rear of
mine with 9mm in the front with my H&Rs. Check out my links below to see if that's close to what you're after (hope the links work - sometimes it redirects
and I don't know why). My personal look is to have a finger's width before the
arch begins (close to 5/8").
Oops. The pic with the benz from the side is 9mm in the rear. I've since installed
the 17mm and it's perfect!
Bob
Old Nov 24, 2004 | 08:09 PM
KenzBenz's Avatar
1995 C36
from the pic...you car doesnt look high at all, you shoulda seen mine, it was way higher than that before.
Old Nov 24, 2004 | 11:06 PM
040mercedes's Avatar
C280
Anyone know where I could find these pads??
Old Nov 24, 2004 | 11:21 PM
Benz916's Avatar
1998 C230
What up Ken...I thought u were only on club202. After my brother seen your car at Kragens, he wants to lower the car now. Look what u did.
Old Nov 25, 2004 | 06:28 AM
trbo2nr's Avatar
I got mine from Phil at http://www.mercedesshop.com/
If you need exact part numbers, I can post a reply when I get to my primary
pc with e-mails from Phil.
Old Nov 25, 2004 | 11:36 AM
KWiK's Avatar
your dealer...
Old Nov 25, 2004 | 06:45 PM
!!!!!NJ Drive's Avatar
agreed...depending on your area road conditions, I would lower it jus one pad size down
I thought I heard, correct me if I'm wrong, isnt the pad size about 1 finger space (ex: #4 to #3 = 1 finger lower...#4 to #2 = 2 finger low)
Old Nov 26, 2004 | 12:40 AM
KenzBenz's Avatar
1995 C36
LOL sorry but its gonna happen sooner or later cant blame me hehe im on bnzsport also =)
Old Nov 26, 2004 | 02:10 PM
C280
I went to mercedessop to check out these pads. They're called coil spring shims, correct? They only give me the option of an 8mm and a 13mm. With stock springs the 8mm would lower it the most right? Does anyone know how much it would lower it? Also does it change the way the car rides, or does it have no effect at all?
Thanks guys
Old Nov 26, 2004 | 03:03 PM
trbo2nr's Avatar
Thanks guys
It all depends on what's in there right now. Need to find this out and work
from there.
8 Millimeters equals 0.314961 Inches (just for reference)
IMO, I can't tell any difference in ride by lowering it with pads alone.
Old Nov 28, 2004 | 01:34 AM
sctrojans's Avatar
w202
what size tires are you running on?
Old Dec 2, 2004 | 05:10 AM
KenzBenz's Avatar
1995 C36
hey benz916, didnt know you went to ucd, i think i saw you car today when you were turning out to russell blvd
Old Dec 6, 2004 | 11:11 PM
Benz916's Avatar
1998 C230
Sorry guys...I been gone for a dental school interview.
As far as tire size go...i have 225/40/18 in the front and 255/35/18 in the rear.
Kenzbenz, I thought i told u i went to ucd. I am graduating this spring. You probably did see me on russell because i park at the parking structure by the MU.
Old Dec 7, 2004 | 03:15 AM
KenzBenz's Avatar
1995 C36
oh yea, thats right, my memory sucks as you can see...but hope your interview went well. Did you know theres a club202 meet coming up, you should come theres a good amount of 202's that'll be there.
Old Dec 7, 2004 | 05:21 PM
Benz916's Avatar
1998 C230
When and where? I would be down.
