Check Engine Light
Week 2...light on again back to merecedes.......100.00 again same issue but did not find any problems. You guessed it 3 day later...same thing back to mercedes which is a 1.5 hr trip each way....and same issue. They could not find anything wrong.
Hub cap is tight, car was not filled while engine running. Using high test. I have been reading all the threads for days now. How can I reset this light myself.....but better yet...how do I find out what the cause is.....mercedes cannot seem to find it nor care...except for the money.
I have seen disconnecting the battery as an alternate...but do not know if this is correct since it was said....in such a derogatory manner. I could sure use some help here if possible........as I do not want damge to the engine nor do I want to keep paying 100.00 for nothing more than turning off a light. Thank you for any assistance.
P0170 fuel trim malfunction- Bank 1
P0173 fuel trim malfunction- Bank 2
Any other codes, post them here and someone can tell you what needs to be replaced. That Mercedes Stealership you're going to sounds worse than most---most will at least give you the codes and diagnosis for the $100!
http://www.iequus.com/item.asp?cid=10&pid=3100
It'll be the best $ 140.00 you'll ever spend.
This works on any vehicle ( from 1996 on ), NOT just M-B.
I do have the radio code...from the dealer provided it is trhe original radio. Just do not want to test it out though. Would rather know what is wrong and why light comes on. The car runs wonderful, not rough at all no hesitations.
I will have a tune up done and all emmisions items replaced as you said and see if that helps. Thank you all for the help.
gamma have you tried the company that made your scanner's website?, short of that just hook it up to someone else's car and start hacking :v
My 220 has problem w/ p0170 on n off for the last 2 years. I reseted it today but seems like I have to solve the problem for SMOG. Both O2 sensor has been changed, the MAF has 1000 miles... fuel pressure regulator has 400 miles. But right after changing the fuel pressure regulator, the light came on... I'm using the Autozone scanner to erase the code. could there b anything else that would cause this problem? How about fuel filter? fuel tank cap? plz help...
By the way, the throttle sometimes hestitates, rpm revs up a little but drop to bottom, often happens at idle. Also, when accelerate to the floor, feel like the fuel pumps arent strong enough and hestitates. Other than that... it average about 360-380miles per tank.
