c230 engine help needed
Old Dec 18, 2004 | 03:14 PM
maxim's Avatar
Hello,
I have a 2000 c230 kompressor and lately the check engine light has been on. The readout code is p0410 secondary fuel injection system malfunction. Could anyone help me out as to where to locate this system and how to fix it?
Thank You!
Maxim
Old Dec 18, 2004 | 04:58 PM
meanie's Avatar
The code stands for secondary AIR injection.
Best let the dealer check this, as it can get a little complicated.
Old Dec 18, 2004 | 07:29 PM
maxim's Avatar
I used to have a 1998 BMW 323 and had a simular problem. I wound up having to replace an airpump (about $175 I think) . The actual problem was that the airpump had a little air filter which wasn't replacable and the filter media broke down and gummed up the insides of the pump. THis pump sends air into the exhaust when the car starts up to even out the emmisions levels.
I'm thinking this may be the same thing? If so can't I just replace this air pump ? Where is it located?
Thanks!
Maxim
Old Dec 18, 2004 | 08:27 PM
meanie's Avatar
On a C 230 Kompressor, the super charger acts as THE airpump on a cold start ( for about 1 - 2 minutes, to warm up the cat. converter ).
BUT, this also involves switching electric vacuum solenoids, check-valves, etc.
Rather than guessing, I would suggest to visit the dealer, have them run a diagnostic check & hopefully pinpoint the exact problem.
Old Dec 27, 2006 | 08:32 AM
john89011's Avatar
MB C32 AMG
I had the check engine light come on with p0410 and all I did was disconnect the negative on the battary, tap the brake 3 times to discharge the electricity and wait 2 min and it went away. I tried to erase the code with the scanner but it would not work.
Old May 13, 2008 | 09:25 PM
SParkyMerc's Avatar
I got this P0410 code today!
Taking to a dealer next Week, will update what it is about exactly.
