Glove box issues
Old Jan 5, 2005 | 11:43 AM
BenzMan1's Avatar
Glove box issues
Yesterday my glov box door stopped closing. It looks like the striker latch disconnected from the black backing on the interior of the door. Does anyone know how to get the glove box door off? I am going to try to fix the latch by using epoxy to adheir it into posistion. This will be a lot cheeper than replacing the door @ a cost of $185.00
Old Jan 5, 2005 | 01:03 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I doubt that epoxy will be good enough to hold it. To save some bucks, you may want to check a local dismantler (junk yard). There are quite a few W202s in junk yards these days.
What color are you looking for?
I think it is easier to remove the whole glove compartment first... there are clips at the top and bottom, and then after those are removed you have to wedge the whole thing out.
-s-
Old Jan 5, 2005 | 09:48 PM
BenzMan1's Avatar
Here are some pics
Attached Thumbnails Glove box issues-dsc00263.jpg   Glove box issues-dsc00264.jpg   Glove box issues-broken-latch.jpg
Old Jan 5, 2005 | 10:06 PM
RunInColorado's Avatar
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
If you go the glue route, instead of epoxy, try "Liquid metal." I have found it works much better than epoxy and is even black to blend in more with the box.
Old Jan 5, 2005 | 10:29 PM
BenzMan1's Avatar
Where did you buy it? Can I get "liquid metal" at home depot?
Old Jan 6, 2005 | 08:21 AM
Last time I used the stuff I borrowed it from my Uncle. Since he lives in a small town the only 2 choices where he could have bought the stuff was either at Lowes or Walmart. I think I have seen it at Walmart but I dont remember. I would call around before chasing it down but Im pretty sure it is called Liquid Metal. Also, you can sand and paint it for the perfect look. If you cant locate it, Ill write my Uncle and ask where he found it. Just let me know.
Old Jan 6, 2005 | 12:25 PM
BenzMan1's Avatar
Than ks for the info...I'm not worried about the look of the repair. That part actually lives between the front and back of the clove box door.
Old Jan 7, 2005 | 09:23 PM
BenzMan1's Avatar
The fix was $3.95. A tube of JB Weld and all is well.
Old Jan 7, 2005 | 10:29 PM
Glad it worked out well!
