i have a problem? anyone help?
Old 01-05-2005, 08:30 PM
Euro94C280's Avatar
ok in my girlfreinds c280, some times after a while of driving, the speedometer with lag when taking off an out of nowhere Kick in at around 20mph, and sometimes the tempm tach and speed all didnt work one day , thn came back on later on, the next, i couldnt think of any fuses or anything to check?, do u guys know what that problem can be?
Old 01-05-2005, 09:59 PM
13benz's Avatar
98 C-230
Hi Euro.
Sounds electrical if more than one of the gauges are failing. I would check the fusebox, if that's ok i would start running wires out to make sure there isn't a bare spot on one of them and that the connectors are clean and tight. Have you ever been under the dash? maybe something got pulled loose from the cluster assembly, or a spliced wire isn't making connection all the time. good luck
Old 01-05-2005, 10:13 PM
meanie's Avatar
The needles on the gauges are sticking.
In order to repair this problem, the instrument cluster would have to be pulled out, taken apart & the needles & stop pins cleaned.
Old 01-06-2005, 12:47 PM
DougandhisC280's Avatar
2008 SLK-280
meanie is right. This is a common problem. One of these days I'm going to video my speedometer going from 0 to 60 in half a second.
Old 01-06-2005, 10:53 PM
13benz's Avatar
98 C-230
I've never heard of that happening, but i have only been a MB owner for a year or so, it's good to know what is a common problem, so thanks for the heads up.
Quick Reply: i have a problem? anyone help?
