96 c220 maintenance manual
If you just mean a good Maint manual for instructional purposes, I suggest the Haynes Manual that covers the C-class.
I too have a '96 C220 and have found the Haynes manual to be of great assistance.
Matt
thnx for your help!
As for the MB specific literature, I would call your local MB Dealer, ask for the parts department, see if they can't give you the MB Part Number and give you pricing or go ahead and order it for you. I imagine it will be a special order part that is not stocked local.
As for weird noises, I do have a couple things right now. The power steering is starting to whine for no apparent reason, alignment is fine, tire pressure is okay, so I don't know what to make of it yet. I also have a really bad vibration over 80mph and it is not the tire balance nor either the front or rear flex disc, I don't know if maybe it's a support bearing for the drive shaft or something of that nature.
I recently corrected a noise under the hood that turned out to be the acessory belt tensioner, it busted and was causing the belt to make noise.
Let me know if there is something else your car is doing, maybe we can determine if it's something with the model.
Matt H
Denver, Colorado
i wonder if yours does that also
thnx
