tire size
Old Jan 22, 2005 | 03:09 AM
vdubpower's Avatar
i drive them all, fast and hard
tire size
whats the correct tire and wheel offset if i want to get 18s, either monoblock or brabus copies for a 97 c280
should i get them staggered.
i probably will lower the car too,
Old Jan 22, 2005 | 06:25 AM
MikeL's Avatar
Uber 202
offset should be ET 35. Tire for the fronts you should run 225/40/18 and the rears you can run whatever you want. I run 225/40/18 fronts, and 255/35/18 rears. 225/40, 235/40, all the way up to 255/35 will fit fine in the rears.
Old Jan 22, 2005 | 10:21 AM
meanie's Avatar
Two more things to consider when you run staggered.
1. If you buy directional tires, you can not rotate any of them.
2. For 225's front & 255's rear your wheels should be 8" wide at the front & 9" wide at the rear.
Old Jan 22, 2005 | 03:41 PM
vdubpower's Avatar
i think the 225 40s should be fine all around, performance wise i assume difference is minimal
if i do 225 40s is there any point in geting 18 by 9s rear or just stick with 18 by 8
Old Jan 22, 2005 | 04:51 PM
meanie's Avatar
Stay with 8's. That way, at least you can rotate your tires front to back.
Old Jan 22, 2005 | 05:28 PM
vdubpower's Avatar
can someone tell me if these would fit fine, i think they are 38mm offset 18 by 7.5
WHEELS
Old Jan 22, 2005 | 06:44 PM
meanie's Avatar
They will work 100 %. They even have the correct centre bore, so you don't need centering rings.
Nice looking wheels too.
Old Jan 22, 2005 | 08:44 PM
vdubpower's Avatar
what do u mean by center bore. ?
so being 38mm it wont matter? how much of a difference does matter?
im not sure who makes these but they are very sweet looking . i guess they are brabus replicas. wonder why brabus didnt patent them, lol
Old Jan 22, 2005 | 09:46 PM
RunInColorado's Avatar
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
I saw those rims on a Benz the other day around town. They looked great! Nice choice!
Old Jan 23, 2005 | 09:19 AM
meanie's Avatar
The centre of the wheel, where it seats against the axle, is the correct size for M-B's.
Most aftermarket wheels have a larger bore ( so they can fit a variety of vehicles ), and then use a plastic or metal ring insert,( bushing ) to reduce the too large diameter to the correct size for the vehicle.
These are called hubcentric rings, because that is what they do, centre the wheel on the hub.
If you don't need to use them, all the better.
The 38 mm offset just moves the wheel IN 1/8" more than a 35 mm offset would.
Means absolutely nothing when you're going with a 7.5 or 8" wheel.
Sometimes you may see offsets of 20+ up to 50+ wheels offered on ebay. These would not fit your car, as they would move the wheel in or out much more than the body can handle.
Old Jan 23, 2005 | 11:24 PM
Benz916's Avatar
1998 C230
I have those rims on my car. Same exact thing except I have 7.5 in front and 8.5 in rear. I believe the offsets are 35mm and 38 mm. I have posted pics on this site...on the c class picture thread. The tires that i am running are 225/40/18 and 255/35/18. Look perfect.
https://mbworld.org/forums/showthrea...&page=53&pp=10
I even located the link. :p
Old Jan 23, 2005 | 11:32 PM
Benz916's Avatar
1998 C230
https://mbworld.org/forums/showthrea...&page=52&pp=10
here are some more...better close up of the rear.
Old Jan 24, 2005 | 02:52 PM
vdubpower's Avatar
the company that makes these wheels, velocity motoring said that the 35mm will rub on the car but the 38 will be fine. they said the car comes stock with 45mm offset?
what do u think
Old Jan 28, 2005 | 05:00 PM
Benz916's Avatar
1998 C230
Nothing rubs on my car. Everything seems fine and i do have 35mm offset and 38mm offset.
Old Jan 29, 2005 | 12:17 AM
DougandhisC280's Avatar
2008 SLK-280
I have 35mm offset on 18 by 8'' wheels on a heavily lowered car. I am yet to rub for the first time.
