Audio 10 update
Old Jun 12, 2002 | 04:03 PM
session's Avatar
2007 VW GTI
that's what the one i just bought looks like... i don't see a logo on the front either. let's hope it looks as nice after it's been through the post!
Old Jun 14, 2002 | 07:45 PM
Buellwinkle's Avatar
The race is on to who get's it first! My second one left Munich yesterday on a slow boat. My first one finally made it to Becker and it's sitting on someone's desk is all they were able to tell me after a week. Arrghhhh!
Old Jun 15, 2002 | 01:24 AM
Lynn's Avatar
Hey, Rick
Is that your sales monkey?:p
Old Jun 15, 2002 | 10:51 AM
WebGuyNJ's Avatar
2002 C230K
Originally posted by neil1
I am talking about the one in the front, obviously it has a factory serial number and logo on the top. I didn't receive the original box but the manual came with it.
Mine has a seal on the front. Hmmm I'll look again and see if there is some kind of part number on it for you.
Old Jun 16, 2002 | 01:36 AM
shortbear's Avatar
they sell it on Autoclass.net for $649. It is sort of expensive.
Old Jun 21, 2002 | 10:19 PM
I got my radio and it is working great. The CD player works, the CD changer works, the sound is soooo much better. I like the RDS. On one station it displayed the 'Playing Usher on KIIS FM'. I set all 8 presets. The only unsual thing so far is you can not switch from to the CD Changer while the CD is playing, you have to switch to radio and then back.
Old Jun 21, 2002 | 10:31 PM
  #32
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Yes, you can! tap on the CD button once, it should switch to the changer. Any word on the manual?
TIA
Old Jun 21, 2002 | 11:26 PM
  #33
Haven't heard on the manual from Becker yet. I would imagine we can contact a dealer in the UK and get it . I have the German manual and I pretend I understand it. Here's a pic for people that are concerned that the CD changer works with the Audio 10. It shows the CD number and the track number that's playing. I'll post some pics of the vent that needs to be removed so those that install themselves understand what's going on.
Old Jun 21, 2002 | 11:29 PM
  #34
These are the tabs that you press to release the vents so you can rotate them up to access the torx screws on the bottom and release tabs on top.
Old Jun 21, 2002 | 11:31 PM
  #35
These are the clips that you have to pull down from inside the top of the vent. Stick a thin flat blade screwdriver in a slot on top and pull down and tug on the vent.
Old Jun 21, 2002 | 11:32 PM
  #36
Here's a side view of the clips that must swing down to release the vents.
Old Jun 21, 2002 | 11:34 PM
  #37
These are the torx screw that you access by rotating the vents up after pressing on the tabs....
Old Jun 22, 2002 | 12:48 AM
  #38
I wish I can get a good picture of the spring clips at the bottom but you'll have to take my word for it. Open the ashtray half way and you'll see (or at least feel) the two clips (one on each end on the bottom of the panel). You pull them down with a screwdriver until they release.
Once you have the panel out then removing the radio is a cinch. It's held in with two #20 torx screws on each end.
DO NOT PLAY THE RADIO WITH ONLY THE POWER PLUGGED IN. I DID ONCE AND GOT A "PROD" ANTI-THEFT LOCKOUT.
Old Jun 22, 2002 | 01:53 PM
  #39
speedfrk's Avatar
C230 coupe 6sp
Buellwinkle, do you remember which wiring harness connected to the plug behind the A/C fan controller? I have 2 that have the same plug, and I don't want to burn anything up. One of them is 3 black wires molded together, and the other is 3 colored wires just taped together. One of them must not plug into anything, but I don't remember which one.
Old Jun 22, 2002 | 04:53 PM
  #40
vadim's Avatar
I don't remember which wires wenr where, but maybe this picture will help you?
Old Jun 22, 2002 | 04:58 PM
  #41
speedfrk's Avatar
C230 coupe 6sp
The one you have showing is the black 3 wire molded lead. If you look at my picture, you will see another lead next to it that has 3 milti-colored wires. Any idea where it goes? I cannot find any other plug that it would fit into.
Old Jun 22, 2002 | 05:02 PM
  #42
vadim's Avatar
I don't recall seeing the colored one... Only those on my pic had been disconnected and than reconnected. All has been fine since. Hope this helps.
Old Jun 22, 2002 | 05:33 PM
  #43
speedfrk's Avatar
C230 coupe 6sp
I think the milticolored harness fell down from up above because it is much longer than the black one, but there is still nothing to plug it into. Maybe it is for an option I don't have. Thanks!
Old Jun 22, 2002 | 06:10 PM
  #44
Lynn's Avatar
Since our cars are pre-wired for Tele-Aid, COMAND, and telephone, your mistery wire bundle must be related to one or more of those items.
Old Jun 23, 2002 | 02:50 AM
  #45
Sorry, I didn't disconnect these, only the radio connectors and the top small square plug for the airbag light.
