Help Need with TV tuner programing
Old Mar 5, 2005 | 05:46 PM
cliffybabe's Avatar
CLK Coupe 200 Komp 53 Plate
Hi Guys
I have installed the tv tuner into my clk, it works fine in the sense av1 plays great and the tv picture when tuning is great.
However once stored and i try and go into the tv channle you get sound and no pic, i get a tv with a cross through it indercating no signal however it works fine when tuning in and through av1 can anyone advise.
Neil
Old Mar 5, 2005 | 06:21 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
You set your country correctly and it took it?
-s-
Old Mar 5, 2005 | 06:55 PM
cliffybabe's Avatar
yeah set gb and ireland, pal.
It took it it give a great pic on fine tuning etc savve the channel and then go into normal tv modeif you like and all i get is audio with the tv with a cross.
its really weird
Neil
Old Mar 6, 2005 | 08:26 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
besides the country code, there is nothing that can be programmed in the MB TV tuners...even without the country code set properly, the TV tuner works as it should...
greetingz,
Old Mar 6, 2005 | 08:53 AM
cliffybabe's Avatar
Steve is there anything you can suggest.
I have tried taking out other coding to no joy, it just puts them back in.
I have tried going up the road to get a better signal no joy.
I now can recive teletex
But it still wont show a picture on the screen once i have tuned it in.
It tunes a great picture but once i save it and return to normal vieing i just get a black screen on the tv with a cross through it
Neil
Old Mar 6, 2005 | 06:14 PM
cliffybabe's Avatar
Please can someone help, I have spent the hole day tring different tuning etc, it will not display anything except the av channels and when in tuning mode for the tv, when i save and go back to normal screen the picture is not there just a black screen with the tv programs sound only.
I dont think its cabling issue as i wouldnt have anything at all, I went into comand diagnostics via fm, mute 1&2 and it doesnt show the tv tuner as being ticked is this the issue?
ANY HELP would be great as im really stuck and its starting to depress me.
Neil
