Auto-down windows with keyless remote
Old Mar 9, 2005 | 04:55 PM
hkalltheway's Avatar
2005 C230 sedan w/ Bixenon, auto tranny, sunroof, garage opener, rain-sensing wipers, black on black
Hey guys, I have a 2005 C-class. I haven't had any major problems so far. It has about 7400 kilometers, and I got it in November 2004. One thing that's bothering me is the fact that I was told that if I hold down the unlock button on my remote, all windows and sunroof should open, and when I hold the lock button, they should all close again. Well, I tried holding unlock for a good 30 seconds, and no luck. nothing happened. I even tried holding the lock button for a while, and nothing. What could be wrong?
Old Mar 9, 2005 | 04:57 PM
oel's Avatar
oel
C230 coupe, 335i
you have to point your remote to the "sensor thing" beside your door handle.
Old Mar 9, 2005 | 05:01 PM
I'm at school right now, and will be going to the car in about an hour. Can it be from a distance, or do I have to stand right next to the door to do it? I was always under the perception that on a very very hot day (I used to live in the Middle East), one would be able to open all windows and sunroof from a good distance away for ventilation, so by the time the person gets to the car, all the extreme heat has gone out. I've even seen that on BMWs. They can do it from a distance. Is there a purpose to having that sensor and not being able to open from a distance in this case?
Old Mar 9, 2005 | 05:04 PM
GGM's Avatar
GGM
2008 E350
In my experience, you have to be right up on the door and pointing the remote at the sensor in the door handle. It never works on my car from ANY distance. And you really have to be pointing it at the sensor (it's a dark square/rectangle on the end of the door handle).
Hope this helps.
GGM
tommy's Avatar
2004 Civic Si. FWD for the Win!
You have to be close. It's still better on a hot day than getting in, and opening up them normally.
If yours still don't work, you may need to re-snych the windows and sunroof.
Old Mar 9, 2005 | 05:13 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
ive noticed you cant be too close either. leave a couple inches distance. also remember, on 2005 there is no IR sensor on the passenger door. so you have to be on the driver side of the car.
Old Mar 9, 2005 | 06:54 PM
trench's Avatar
2002 C230 K
Actually, I've noticed that since it's an IR sensor it doesn't work from as far away on a hot day or in bright sunlight.
Old Mar 9, 2005 | 07:11 PM
MB-BOB's Avatar
Admin Alumni
See Garage
You can get further away, but the IR beam from the remote is very narrow, so you have to aim it just right at the sensor or it won't work. 10-12 feet away (3-4 meters) is about the maximum distance away that you can use this feature on my car. Maybe 20 feet (6 meters) with perfect aim, but who wants to draw a bead down the remote with one's eye on the parking lot?
A cute parlor trick, but essentially-useless if you thought you could open the windows from across the parking lot. I use it mostly when I get out of the car, lock it, then realise a window or sunroof is open.
BTW, this feature uses the IR side of the key, while the door locking/unlocking uses the RF transmitter, so it functions from much further away. I would have been happier if the window down/up feature worked on the RF, as well.
Old Mar 9, 2005 | 07:12 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Actually there is a trick to this that works at long distances. Thanx to Revstriker who posted this a long time ago. Also be aware of your biological makeup; it works opposite for left versus right handed people.
Hold the key up to the correct side of your temple on the side of your head. Press the corresponding button that initiates the function you want to activate. This will then allow your brain cavity to amplify the signal. the reason for this will be the added electrical impulses generated by your thinking processes. Remember to think real hard. HTH
Old Mar 9, 2005 | 07:18 PM
MB-BOB's Avatar
Admin Alumni
See Garage
I'll have to try that one again myself, Andy, but I recall that the IR beam doesn't work on the resonance principle as the RF side does.
And you're joking about thinking really hard. The RF signal DOES amplify off the bony structures in your head, like your temple or your jawbone. Works the same way that a dolphin projects its sonar signal in the ocean (through it's lower jaw)
The IR side doesn't work as well during very sunny days simply because the aim has to be perfect for the sensor in the door to distinguish the threshold difference in the IR beam from the overwhelming ambient light already present. Doesn't have anything to do with ambient temperature, unless you've left the remote in the direct sunlight and the batteries are overheated.
Old Mar 10, 2005 | 05:36 AM
formula1's Avatar
'06 CLS350, '07 E200K, '05 BMW525
Wow, I never knew the C class could do that. It was one of the things that facinated me when I test-drove the Beemer 330CI.
I'm gonna give it a try.
Old Mar 10, 2005 | 11:18 AM
just some of the things you can learn here if you dont read your manual.
Old Mar 10, 2005 | 12:05 PM
revstriker's Avatar
K Car
Actually, from a distance, if you stick your IR transmitter in your mouth, and aim your butt toward the sensor........
Just kidding. :p
Old Mar 11, 2005 | 01:19 AM
formula1's Avatar
I never read the manual. Anyways, I tried it and it works. From 2 inches to 6 feet, so long as the remote is pointed towards the IR sensor.
Old Mar 11, 2005 | 06:08 AM
Moviela's Avatar
I accidently put my car key in my house door.
And it started up!
Old Jul 5, 2006 | 02:47 PM
XRAYVSN's Avatar
2004 C320 pewter/charcoal
Although in theory this feature would be beneficial, the distance you have to be at to activate it essentially means you're right there to then open the door and still be subject to the high heat inside. Would have been so much better to have it work while the car is in visual range to open it and have some time for the heat to disappate. Also, in my 2004 model, IR appears to be only on the driver's side so if I approach it from the other side (which more times than not I end up doing) it won't work from the passenger side.
Also it takes holding down the button for a decent amt of time before it takes effect (and at that range, might as well open the door and vent out the heat that way).
Not the smartest designed system in my opinion.
Old Jul 5, 2006 | 03:26 PM
e1000's Avatar
a quarter mile at a time
um - you dug up this thread to say that?
Old Jul 5, 2006 | 04:14 PM
drho2004's Avatar
2005 C230 SS
yea it works only sometimes on my car too. and u have to be pretty close for it to work, so its kinda useless since u gonna get in the car almost right away.but i do use it when i forget to close the sunroof and i close it as i lock the car. but yes it would have been much better if it worked at the same distance as the lock/unlock mechanism
Old Jul 5, 2006 | 04:55 PM
BeaverMjr's Avatar
2015 C350 Coupe
remote window open
I was at a friends house and his brother wanted to see the car. I opened the windows and roof w/ the key to show him the inside. This way I didn't have to open the doors. Also great on a summer day when the car is parked in my driveway and I want to cool it down while inside my apartment.
Just my 2 cents, but I like the feature.
Old Jul 5, 2006 | 05:34 PM
XRAYVSN's Avatar
How else am I going to maintain my blazing post rate of 276 (now make 277) posts in under 2 yrs?
And instead of starting a new thread regarding this topic, I actually did STFF!
Old Jul 5, 2006 | 06:11 PM
e1000's Avatar
LOL - you gotta pace yourself - you're gonna mess up your post-per-day if you keep this up!
Old Jul 5, 2006 | 06:49 PM
advans's Avatar
C55 ///AMG, 535xi
this feature is useful but annoying lol,
on my old maxima I could be 3 blocks down and still open all the windows.
Old Jul 7, 2006 | 01:34 AM
Tangerine's Avatar
Is @ Home
they come standard on all the mercedes rite? cuz it says i have it (according to the car manual and my sa) but when i tried it, it doesn't work. i tried it from 1-6 feet and still no luck.
Old Jul 7, 2006 | 12:45 PM
Dub4Life's Avatar
05 C230 & 04 GTi
Mine works when it feels like...
Old Jan 16, 2007 | 12:41 AM
sirenebekim's Avatar
yeah thats how mine is, would replacing the key help with this? It could be due to a scratched IR filter
