Confused about climate control
I'm confused about 2 of the controls:
1) Page 161 explains that the center thumbwheel (the one between the two center air vents on the dash) adds outside air to the air outlets.
2) The air recirculation button (described on page 167) sounds like it does the same thing. It is either activated to allow only recirculated air or deactivated to allow fresh air.
How do these two similar buttons work together?
Also, what is the point of the "auto" button for climate control. If the climate control is supposed to match the exact temperature you set...this seems somewhat "auto" to me. I guess the auto feature is just controlling which vents will be used?
When you press the auto button, the climate control is fully automatic, i.e., it regulates both fan speed and air distribution. Otherwise only the temperature is automatic.
The recirc button does what all cars do, it closes the fresh air intake to the cabin and recirculates the interior air. This helps reduce bringing in "noxious" odors, and maximizes cooling/heating.
As "ahost" has said, when "auto" is engaged, the system will control all functions including air temp, distribution and fan speed. Turning off "auto" allows you to manually direct air to various vents and control fan speed yourself. If you just want outside ambient air, you need to disengage "auto" and engage "EC" (economy) mode to turn the compressor off. In any event, the system will attempt to maintain the cabin temperature you have set on the dials.
As you probably already know, you turn the "automatic" climate control system on/off by pushing the buttons (labelled "Auto") in the vent control knobs to each side of the display. This also resets the fan to "auto" mode (see display), but you can then disengage "auto" fan separately as noted above.
I believe these buttons function differently from the C320 to the C240... The manual discusses both systems, but is not very clear to the user.
I agree with other assessments on the blue thumbwheel. As MarkL said, if you're in heating mode, and want a little cooler air on your face so you don't fall asleep at the wheel, the thumbwheel can be helpful. Can't imagine adding any untreated air when in A/C mode, however, (esp. recirc mode) so I keep my thumbwheel closed in Summers too.
You're in good company SFC320. The climate control systems on these cars are very complicated, or at least, their use is not at all intuitive to a driver.
, you're pulling a Tommy? Just leave the darn thing on "auto" and be happy
. Just kidding, but hey, there's a manual control for fan speed, air direction and temp. Not too hard. Yeah, the digital system has a couple extra buttons like charcoal filter and the like. Instead of saying complex, I'd say M-B gave you options that you can choose to use or leave it up to the system. Most other auto systems have a manual mode (air direction) and fan control -- can't figure out why people think M-B is more complex? Saw this in some articles too. Oh well...
Has anyone had it fixed? The only thing I LIKE about it is it sounds like a jet engine when the fan speeds up or slows down
All the other times I just want it to SHUT-UP!
Oh no
[B]
I did some initial experimentation w/ the "blue wheel" when I first got my C240. I'm not sure it really adds "outside" air, as much as cold air to the center vents during heat mode. In cooling mode, there is no apparent effect.
I agree. I think, once you figure it out, the system is very functional and logical. The auto works very well, and if you want you can control the airflow very specifically.
Ok, I've got the whistle and it drives me freakin' BANANAS!
Like young said, if you move the blue wheel up just a tad from fully closed (down) the whistle should stop. And, at that position, you should only get a very small amount of cool air from the vent during heating -- not enough to be annoying. I think I only heard the whistle when the fan was running at a pretty high speed. To test, just set the thing on manual, direct air to the floor vents, jack up the fan speed and try the blue wheel until the whistling stops. Good luck.
I like the auto system very much. Once you get it figured out, it's not really that difficult. I normally have the auto control on the fan, but I leave the vent selectors in manual mode. For some reason in Auto it was directing too much cold air on to the windshield causing them to frost.
I had to play with this to stop/reduce the whistling. It does work. Of course, so does turning up the radio!
am i the only one that hates it?
