What kind of Octane do you put in your C-Class?
Old Aug 13, 2005 | 02:39 PM
  #251
mick1's Avatar
2005 C320wz
Originally Posted by Outland
BTW, 21MPG, that's pretty low for the 1.8, eh? My 2.3 gets always better than 24 in the city, over 30 on my 50/50 work commute loop.
i got the 3.2 liter engine so 21 mpg is all i could get. It's brutal in the city though, sometimes i would see 15 mpg
Old Aug 13, 2005 | 04:38 PM
  #252
E55AMG99's Avatar
1951 Caterpiller D6
Damn! Something must be wrong. My E55 gets 20/16mpg
Old Aug 13, 2005 | 05:02 PM
  #253
mick1's Avatar
2005 C320wz
really?
I got a C240 loaner car recently and it also averaged 21 mpg, so i thought i was doing well getting 21 mpg on a c320
Attached Thumbnails What kind of Octane do you put in your C-Class?-21mpg.jpg
Old Aug 13, 2005 | 05:19 PM
  #254
revstriker's Avatar
K Car
I get about 21 with the 3.2 with an average speed of around 30mph. That's with the AC running.
Old Aug 13, 2005 | 06:54 PM
  #255
GGM's Avatar
GGM
2008 E350
I haven't reset the computer since I got my C240. In 12,000 miles of driving, mostly around town and really short trips to work (3 miles) I have averaged 21 mpg. And I live in Florida so the AC is running all the time. I always run Chevron premium (93 octane).
GGM
Old Aug 13, 2005 | 07:06 PM
  #256
Outland's Avatar
2002 C230 Coupe(M111)
Reality often shows that you will burn more fuel when using an octane rating lower than optimum. When the ECU alters timing, shifting, etc. your engine is no longer runing at peak efficiency. Mileage will suffer in most cases.
Its not about peak efficiency for normal driving. And for everyday driving, you shouldn't be running the engine hard enough for it to matter. It takes so little HP to keep the car moving. And at partial throttle, I'd bet the car makes no less HP than with premium.
Tell you what, I'll challenge you to a tank of low octane fuel, you in your E55, me in my lowly supercharged Coupe. In normal driving, i don't think you'd loose any mpg.
Old Aug 13, 2005 | 08:41 PM
  #257
E55AMG99's Avatar
1951 Caterpiller D6
You are not seeing the entire picture. Very little HP is needed to keep the car moving but how often are you at a steady state, flat cruise? Part throttle is a very key place where higher octane is needed. Load is still fairly high and A/F ratios are very lean. Part throttle knock is the most common occurance in a street engine.
In simple terms, if the ECU reduces output at a given RPM, you need more RPM to create the same HP. More RPM equals more fuel.
I have run all my cars on various octane rated fuels and the only one that does not result in a statisitcal increase in MPG is the Denali. The E55 now has a Powerchip with 93 octane tuning. The numbers on the CLK and Denali are stock. The 93 octane was a mix of Union 76 91 octane and 100 octane. The 94 octane is what I have in my tank on the lake. Even though most boats claim to be 87 rated, most of them run so much better on the high test. My modified SeaDoos absolutely need it. EGT goes crazy if I run 91.
Here are my notes from both Benzes (commuting 21 miles each direction) and the Deanli (lake house to home 60 miles of mountains and 100 miles of freeway). Some of these numbers are averages from a few tanks but none were more that a tenth or two off.
E55 pre chip - 89 octane 16.4 mpg
E55 pre chip - 91 octane 17.7 mpg
E55 post chip - 91 octane 17.1 mpg
E55 post chip - 93 octane 18.1 mpg
CLK430 - 89 octane 15.8
CLK430 - 91 octane 16.4
Denali - 87 octane 14.7
Denali - 89 octane 14.8
Denali - 94 octane 14.8
When I was building engines for people, this is one way I would determine the correct octane rated fuel for their application. When MPG stops increasing as octane increases, this is the right fuel. Without going back to my notes, I'd say that 90% of the vehicles I tested this way in 20 years showed a statistical change in MPG when octane was lowered.
Old Aug 13, 2005 | 10:03 PM
  #258
Tishers's Avatar
'06 C350 4MATIC
Rotten Gas
From the perspective of working as an engineer for Amoco Oil Co for seventeen years I would not suggest using regular grade gasoline in anything other than your lawn mower.
We used to "cut in" "interface" into regular gasoline batches. Sure it was still 99% good-ol gasoline but there was also a component that was anything from #2 heating oil, jet fuel or even water that got into a sump tank.
Old Aug 14, 2005 | 01:15 AM
  #259
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i have lead foot...only around 16-17mpg on avg for me.
Old Aug 20, 2006 | 01:18 AM
  #260
mtnman82's Avatar
'16 E350, gone: '03 c230k
higher than 91 octane???
I did a search but couldn't find anything ..... just wondering if there was any performance advantage to using higher than 91 octane in a c230k. Anyone know if the computer will take advantage of better gas (i.e. raise boost level or advance timing or ???)?
Old Aug 20, 2006 | 04:06 AM
  #261
Tangerine's Avatar
Is @ Home
are you talking higher then 91 as in 92,93? or like racing fuel?
Old Aug 20, 2006 | 11:06 AM
  #262
Buellwinkle's Avatar
No performance advantage at all, tried Unocal unleaded 100 octane, no difference on dyno, no difference in feel.
Old Aug 20, 2006 | 02:10 PM
  #263
BadAssC230k's Avatar
"Double Stuff" SOLD | Nor*Cals "Pesky Audi"
STFF with someting like "octane booster". there was a thread on here not too long ago with regards to octane booster / higher octane gas. A LOT of people had first hand experiences with no advantages at all.
Old Aug 20, 2006 | 06:04 PM
  #264
advans's Avatar
C55 ///AMG, 535xi
I heard that octane boosters are used in the summer months.
Theres really no difference in "feel" with octane boosters.
but theres a diff if I use 88octane fuel rather than the usualy 93
Old Aug 20, 2006 | 07:14 PM
  #265
pookie's Avatar
2013 c300 4matic, 2002 c240
no
Old Aug 20, 2006 | 07:42 PM
  #266
JamE55's Avatar
Out Of Control!
The only way you can benefit from using a higher octane fuel (101, 104+) is if your ECU is modified. Modified meaning it's been programmed for more aggresive and more advanced timing. IF it is then yes you'll benefit from it. I have a custom ecu i'm using and will never go back on pump. Mine runs strictly on 104 and it is a noticeable difference.
Old Aug 21, 2006 | 02:24 AM
  #267
mtnman82's Avatar
Buellwinkle hit the nail on the nose - I now have 95 & 100 octanes available from the pump locally. It's proportionally more expensive than the 91 octane of course, so I would only use it if there was a performance advantage. If Buellwinkle dyno'd with different octanes and says no difference, thats pretty definitive to me. Thanks to all!!
Old Aug 21, 2006 | 02:28 PM
  #268
gens's Avatar
2005 C320 4matic + 2005 ML500
Does that mean that I can use lower octane gas without any disadvantage? I guess not..
Old Aug 22, 2006 | 10:36 AM
  #269
bnzct's Avatar
06 C230
FYI:
MBWorld thread: Shell V-Power New Formula_100 Oktan
Old Aug 22, 2006 | 06:59 PM
  #270
mtnman82's Avatar
bnzct - wow ... I even posted in that thread!!! How short lived a memory can be.....
JamE55 - are you running a stand alone ECU, or did you have your stock ECU reprogrammed (or chipped)?
Old Aug 22, 2006 | 07:37 PM
  #271
JamE55's Avatar
Out Of Control!
Custom programmed ECU.
Old Mar 30, 2007 | 04:47 PM
  #272
progun's Avatar
Fuel
If this has been beaten to death already, I sincerely apologize. I did do some searches and never found an answer to my question "can my 06 C230 Sport (no kompressor) run 89 octane E10 and if so, what do you think are the shortcomings". Gas here in Hawaii is starting to go up again (like everywhere else) and was wondering if going to the next lower octane would be ok and what would the trade-off(s) be. Thanks in advance!
Old Mar 30, 2007 | 05:06 PM
  #273
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
there is lots of discussion about octane here.
https://mbworld.org/forums/showthrea...ghlight=octane
Old Mar 30, 2007 | 06:14 PM
  #274
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
Gas is still very cheap in the US and you also have reasonable pricing on premium running about 8-10cents more per gallon.
Here in Canada (let me remind you we are a net producer of oil) our gas is priced at $1.04/litre regular and $1.15/litre for premium. The 11 cents spread to get premium is the killer as 4 litres = 1 US gallon so that is a premium of 44cents per gallon.
Some how the math got mixed up north of the 49th
Old Mar 30, 2007 | 06:17 PM
  #275
alymo's Avatar
2001 c240, 65 MG Midget...5.0L V8
try 110 for regular 121 for premium...damn taxes
