Rain sensing wipers are annoying!!!
Old Mar 29, 2005 | 05:38 PM
levelr123g's Avatar
unplug the sensor, and they will not come on by themselves
Old Mar 29, 2005 | 06:04 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
That only aplies to pre-'05 W203's. In '05 W203's the rain sensor and light sensor are built into one unit with a single plug.
Old Mar 29, 2005 | 06:58 PM
mbny's Avatar
08' BMW E92 Coupe
Originally Posted by nicedeboy
I read it stupid face, I was responding to the other comments. You can pull that pole stuck up your butt out.
LOL, haven't heard that one since the first grade. i'm gonna have to disagree with you on this though. i've used Rain X in my past 3 cars and have yet to have a problem. i did notice an occasional skipping with my infiniti when it wasn't raining heavy, otherwise, even with the bmw, i haven't had any squeaking or any other annoyances with it.
Old Mar 31, 2005 | 12:09 AM
ffejalink's Avatar
'14 A6 3.0 TFSI
Skipping yes, that's what I was going for (sqeaking was the wrong term, sorry). It was late, I was tired...nuff said. I haven't noticed a difference in wiping interval with/without using Rain-X. Good luck with finding a fix :-)
Old Mar 31, 2005 | 12:26 AM
dgwee's Avatar
C180K
Originally Posted by Jim Banville
With the feature turned off, the first click on the wiper stalk will give you 1 wipe every 5 seconds.
I used to drive a 1980s Toyota Corona and the wiping interval (adjustable from 1 sec to 10 secs) on the first click could be manually varied by turning the control stalk. That was most useful .
Old Apr 4, 2005 | 02:51 PM
JDM's Avatar
JDM
2011 C300
Originally Posted by racee
I would recommend that if you are experiencing problems with when your wipers swipe, you should contact your dealer. My wipers used to swipe when the pollen from trees hit the window... bright blue sky... I took it to the dealership and they had to replace the whole sensor. It works fine now and when I don't want them on at all, I just turn them off and they do not swipe.
...01 C240, same problem, hyperactive rainscence. dealer replaced problematic sensor, they are fine now, maybe even a little slow. We'll see if i can get another 35,000 miles out of the new sensor. Going in for 3rd set of fuel level senders though, next time it $600 for me.
Old Apr 4, 2005 | 03:07 PM
  #32
inFiniTE LooP's Avatar
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
i've used Rain-X spray on window cleaner and Rain-X wipes to clean my windshield and have noticed no differences. my auto-wipers have always worked perfectly and i love'em!
Old Apr 4, 2005 | 04:57 PM
  #33
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yup, i usually just tap the lever myself in light rain.
Old Apr 4, 2005 | 08:19 PM
  #34
I find that solution ridiculous. Why should the driver have MORE work to do in the rain when you're paying extra for "upgraded" wipers?
Old Apr 4, 2005 | 10:22 PM
  #35
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it's standard
Old Apr 5, 2005 | 01:13 AM
  #36
it's standard
it wasn't standard on my car, it was part of the sunroof package which was an option
Old Apr 5, 2005 | 11:04 AM
  #37
mctwin2kman's Avatar
That is all I do as well. Then again I do not need a clean windshield everytime one or two drops hits it.... I normally let the water collect so I do not get annoyed by the dry swipe or not enough water on the window swipe that squeaks like crazy!
Old Apr 5, 2005 | 11:12 PM
  #38
TNblkc230wz's Avatar
C320 Coupe
Originally Posted by lars
Maybe a problem with the new sensor configuration? They work great in my '03.
Mine work great as well.
Old May 6, 2005 | 06:56 AM
  #39
HakkinenL's Avatar
2009 C200K
My rain sensors come as standard.
It is really annoying for me.
During slight rain, just a teeny bit of acceleration can cause the wipers to swing like mad.
Another problem is because my wipers squeak very loudly. If my wipers aren't noisy, probably I won't be annoyed.
I don't have RainX, I am not sure if the squeaking is caused by the Mequiar's car shampoo (I don't use that shampoo on the windscreen but they may have overflowed over it during washing).
Old Dec 20, 2005 | 08:48 PM
  #40
faz's Avatar
faz
'02 C240
I know this is an old thread... I found it using search.
My 02 C240's auto-sensing was working fine, almost too fine.
I replaced the windshield with another OEM one due to a crack, and the new windshield came with a sensor. Of course in sunny CA it just started to rain a few weeks ago, and I am noticing the same thing: in a slight drizzle while the other one would have functioned perfectly, this one just keeps going and going, no different than the ON (low) mode. It sometimes works fine, but mostly works constantly.
I was hoping that I would find out here how to change the sensitivity (like turning a screw or something on the unit), but I guess I am stock with a bad sensor.
Any ideas from anyone??
Old Dec 21, 2005 | 12:53 AM
  #41
Edison_Chen's Avatar
Toyota Camry SE
My 01 S over wipes too..
