Tried to change springs, couldn't get the fronts out?
Old Apr 10, 2005 | 03:41 PM
NMRA92's Avatar
2006 Saleen, 2003 S55
Had enough trouble getting the car on the lift, Got the strut out put it on the machine/tool to take the spring off the srtut. But I couldn't get the top part to come apart or screw off. Ended up putting it back together. I don't think I will have any trouble doing the backs, just couldn't figure out the fronts. And its on a 04 c320.
Old Apr 10, 2005 | 04:17 PM
NMRA92's Avatar
One more question, inorder to fit a bigger rim than the 17's that are on their, I would need a smaller coilvoer setup of front?
Old Apr 10, 2005 | 04:21 PM
nukblazi's Avatar
To remove the upper bearing you need MB Tool part number 203-589-00-07-00... it is a spanning nut...
You don't want to remove the spring without compressing it first. You need some DIY step by step stuff... check your PMs... I can help you
