19" Rims VS. Rolled Fenders
Old Apr 14, 2005 | 10:29 PM
hittin160s's Avatar
2005 C230 Sport Sedan, Kompressor Engine, Brilliant Silver
OK, so here some more input I got today from a well known local rim shop here in town. They put out a few calls for me, said that 20s are not happening on the C230 Sport, also said that you would have to roll the fenders if you were to put 19"s on a C230SS, you would have to roll the fenders. I have also been told by the guys I ordered my rims from said that it would be no problem. So, heres my question. For those of you who have put 19s on a C230SS (preferably 2005), did you have to get your fenders rolled?
Old Apr 14, 2005 | 10:50 PM
ctC230K's Avatar
excites your girlfriend
I thought 19's would fit without mods.
www.velocitymotoring.com has 19's they said they would fit on a stock c230 ss.
Old Apr 14, 2005 | 11:24 PM
hittin160s's Avatar
Thats what I thought too, when I ordered them. Then, afterwards, is when I was told that the fenders had to be rolled. Kinda confused, guess we'll find out when they get here. Scheduled for delivery on the 18th, but my car is also going to be in for my first 1-3K service appointment, get the allignment touched up(with stock rims), and they have to look at the leather on one of the seats. It will be in for service on Wednesday the 20th.
Old Apr 14, 2005 | 11:26 PM
nukblazi's Avatar
It's all going to depend on the offset of the wheel.
Old Apr 14, 2005 | 11:28 PM
essa's Avatar
05 C230K SS and 02 C240
You could put 20 on your car, check Official C-Class Picture Thread page 116..but I don't know how sinyo1 made it to fit, with or without rubbing...esspecially on the front wheel.
I have 05 c230k with 19 staggered on my car and no fender rolling. Rubbing or not is depend on how low you lower the car.
Old Apr 15, 2005 | 08:59 AM
taylor192
Guest
Posts: n/a
Absolutely.
The coupe has less clearance than the sedan. I have 19" wheels 8.5"/9.5" staggered, 37mm offset, with 235/265 tires and no rubbing at all.
A few people have put 10" wheels with 275 tires on the rear of the coupe/sedan. Just requires the correct offset.
Old Apr 15, 2005 | 12:47 PM
xxbenzc230kxx's Avatar
is not yet completed
i have 19s staggered.. my car is pretty low... my fender sits bout a finger above the rim.. so some tire is still visible.. i had to roll my fenders... it depends on the offset and on how low your car is..
Old Nov 13, 2005 | 03:20 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
Alright, I'm resurrecting this old thread...
I'm planning on lowering my car with H&R Springs (rear pad 3 or 4 b/c I don't like the rear a lot lower than the front), my current wheels are set up with an offset of +31mm in the fronts running 235/35/19 and an offset of +37mm in the rears running 265/30/19. I'm using +3mm hubcentric spacers/centering rings on all four wheels. So I guess the offsets would be +34mm and +40mm respectively.
Do I need to roll my fenders? I know ef1motorsports charges $50 per corner to roll, so I was thinking of just rolling the rears if needed. I'm honestly hesitant of rolling my fenders b/c I'm worried that it could damage the body/paint...
Sorry if this is a n00b question, but I've searched (hence bringing back this old thread) and I just want to do it right... Plus, we know the suspension is changed for 05 and up, so there aren't that many 05 and up threads regarding issues like this.
Thanks!
-Phil
Old Nov 13, 2005 | 03:29 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Thanks!
-Phil
let me answer the noob question with 1 word: YES!
ask me more on aim...LOL
Old Nov 13, 2005 | 11:51 AM
BIGjohnny's Avatar
/////AMG
running on 19x8.5 fronts and 19x9.5 rears. both front and rear fenders covers about half the tire's wall (no gaps whatsoever). have super street tein coil overs with 12.15 mm front spacers and 7.1 mm spacers in the rear. i still rub in the rear.
Old Nov 13, 2005 | 12:08 PM
Karsa's Avatar
How about for the set of 19" TSW Bremma (8.5 ET32 and 9.5ET35), are they gonna rub if I were to put 235/35 and 265/30 Toyo T1R? Also, I will lower the car with H&R spring and whatever spring pad I have on the car. It's for C240 btw.
Thanks in advance for any input
Old Nov 13, 2005 | 01:07 PM
nlpamg's Avatar
So I take it that you did have your fenders rolled?
Old Nov 13, 2005 | 01:17 PM
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Thanks!
-Phil
Phil, I didn't get to go yesterday, but I'm going next weekend for sure, so I'll have info for you by the time I go there. I can check how much they charge for rolling the fenders too.
Old Nov 13, 2005 | 01:40 PM
230Kompressor's Avatar
what do you mean by rolled fenders and staggered wheels?
Old Nov 13, 2005 | 02:31 PM
BIGjohnny's Avatar
/////AMG
oops, forgot to mention... yea only the rear fenders
Old Nov 13, 2005 | 02:46 PM
DACHIGGA's Avatar
2002 CL203
You should not need to roll.
Old Nov 13, 2005 | 04:35 PM
nlpamg's Avatar
all good Drex. if you could check how much they charge for rolling fenders too, I'd really appreciate it. Thanks!
dammit! I guess I shoulda gone with the Bremma's! what a difference 2mm in the front and 5mm in the rear makes...
I guess when I do lower, I'm just going to have the rears rolled.
Thanks for all your help guys!
Old Nov 13, 2005 | 04:59 PM
Karsa's Avatar
Staggered wheels means the rear wheel is wider than the front wheel.
DACHIGGA: Thanks for the input. Really apreciate it
Old Nov 13, 2005 | 05:42 PM
DACHIGGA's Avatar
2002 CL203
NP< but you should still be careful about tire selection, a few mm makes a big difference,
Old Nov 13, 2005 | 06:23 PM
Karsa's Avatar
I think I will go with Toyo T1R F(235/35/19) and R (265/30/19). Do you have any experience with this tire set up? Anyone?
Thanks in advance
Old Nov 13, 2005 | 06:37 PM
AMG_55's Avatar
mymbonline
depends on the width and offset of the wheel
good luck
Old Nov 13, 2005 | 07:15 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Thanks in advance
It'll work!
Old Nov 13, 2005 | 10:13 PM
white_w203's Avatar
is SOLD
offsets are very very critical. if you have to roll the fenders it's not bad.
the tire sizes is the usual size everyone goes with 235/35 with 8.5 front and 265/30 with 9.5 rear.
Old Nov 13, 2005 | 11:57 PM
drexappeal's Avatar
I'm gonna go 19X10 rear.
