Worried!
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Worried!
Several people on the other MB forum w/ the M271 engine have been getting misfires in #4 cylinder. Apparently there is a service bulletin to REPLACE the valves with a new design due to carbon build-up. Before I read about this, I noticed a lot of carbon build-up on my exhaust tip. I'm worried! I don't want anyone to take the head off my practically new engine! My car has about 2500 miles on it now. Has anyone else here w/ M271 noticed alot of carbon build-up on their exhaust tip?
1 Post
04 C320 Coupe MT
The bulletin actually has two procedures, depending on the condition of the vehicle. If there is only minor carbon buildup, there is a procedure for cleaning them that does not require the head to be removed. Only if there is severe cabon buidup would the valves be replaced.
Have the dealer take a look and see which category you fall under.
1 Post
You might want to try http://www.redlineoil.com/products_fueladditives.asp as a preventive measure.
1 Post
04 C320 Coupe MT
I believe there is also a software update for the engine management control unit as well. It has been a while since I read the bulletin, so sorry that I left that out. Maybe I can look it up tomorrow once again and see exactly what it says.
1 Post
Thanks!!!!!!!!! Looking at all that soot on my tailpipe made me think the car was running rich because it was still breaking in.
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
I got 6800 miles on mine and still get the build up, I dont think its excessive though, but that may just be because I had a '94 Jeep with the 318 small block and I'm used to carbon build up! If some one with a white car could chime in and tell us if there is any carbon showing up on the bumper, than that is excessive.
2015 E350 Sport
How do we find out about these bulletins? If there was a problem that was known with these cars, shouldn't something be sent to owners' residences explaining that it can be rectified at the dealer?
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
damn man, this is starting to worry me too. where can we get the info on the bulletin? I know my dealer will probably tell me that there's no bulletin, so I'd like the bulletin number if you could get it. thanks!
OK guys, here is the DTB #: P-B-07.61/46. The service advisor can look it up on Netstar.
Hope you can get it taken care of!
I don't have the problem now, but it's nice to have the knowledge if the problem starts.
Yeah man I have carbon build-up on the exhaust tips. I have a CPO. Can I get taken care of too. Because I just notice its build-ups. Also Can I just get new exhaust tips ? or is it a problem internaly ?
Carbon buildup is a normal occurance on the stainless tailpipe tip. Now if you are getting carbon buildup on your rear fascia then that I would say is a problem. As long as I have been around the car business I have seen carbon on exhaust tips. It is ther due to the combustion process. You should not however have excessive buildup. A little around the edge of the tip. You should see more discoloration of the tip due to heat than carbon. But it is normal for carbon to buildup. And it should easily wash off in most cases, if not get some Mother's!
On a side note my M271 engine has 38,000 miles of my hard driving and it has never once has a misfire on any of the cylinders.
Super Moderator
Originally Posted by dmatre
Thank you for posting this DTB #.
Originally Posted by nlpamg
how would you know if it misfires? would you just feel a lack of power? or funny vibration/sound?
The engine will run rough (will probably stumble), will be way low on power (25%), you may smell raw fuel in the exhaust, and the Check Engine light will come on.
When the Ignition Control Module failed on the wife's Passat (#2 cylinder dead), there was no mistaking that there was a serious problem.
If you experience an engine mis-fire you would definately know it. Trust me, I am on my 3rd C230 Sport Sedan because of engine mis-fire problems with the first two. Read the thread "Am I the Only One..." to get all the details. Both my '03 and '05 reacted exactly the same way when the cylinder #4 mis-fired. The engine "stumbles" initially then runs extremely rough with greatly reduced power until the engine is cut off and restarted. The check engine light also illuminates and stays on.
This thread is the first I have heard of a "common" problem like this. Back in March, when I orginally posted my thread I did not get any indication of others experiencing this problem. Now I am curious to see if the '05 I picked up last week experiences the same problem. So far, the first 350 miles have been uneventful.
