Another 6 speed question
Old Apr 30, 2005 | 09:50 AM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Since my first post went way off topic, I thought I'd ask this question where it might get answered.
I'm pretty sure the light vibrations I feel through the shifter while sitting idle are normal. What I'm not sure is normal is that when I turn on the A/C, the vibrations become much stronger and sometimes feel like a "knock" through the shifter at the frequency of about 2 per second. For those of you with the 6 speed manual that use the A/C, would you mind paying attention for this vibration for a couple of days while sitting at idle with the A/C on after having driven for a while, and let me know something? Thanks!!!!
thanks!
Jim
Old Apr 30, 2005 | 11:37 AM
mbny's Avatar
08' BMW E92 Coupe
i've only used the A/C a couple of times so far, however i did not notice any vibration when at idle with the A/C off. but when i turn it on, i do notice some vibration so i'm guessing it's normal.
Old Apr 30, 2005 | 12:12 PM
Outland's Avatar
2002 C230 Coupe(M111)
Jim,
With the manual, youve got a direct link to the drivetrain, youre going to feel a lot of stuff you never did with the auto. Just drive it. THere's always the warranty.
Old Apr 30, 2005 | 12:51 PM
tyro's Avatar
BANNED
A logical answer could be that Jim has the Delerium Tremens (DT's) now that he, theoritically, got his substance abuse under control, and his hands, etc., are doing the shaking/vibrating.
This is, of course, Opinion only and not a statement of fact.
Old Apr 30, 2005 | 01:14 PM
ctC230K's Avatar
excites your girlfriend
loooool!!
I thought we already answered this question. It's NORMAL. don't sweat it. I feel it too, deal.
thanks!
Jim
i haven't used AC much either. i could try and see for you. :p
Originally Posted by Outland
Jim,
heheheh
ROFL
Old Apr 30, 2005 | 03:06 PM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
Naturally you would feel more vibration with the A/C on. Your engine is now running an extra compressor, which could use around 25-30 HP. Thats quite a bit of strain to put on the engine at idle and not have any extra vibration. And like Outland said... There is a direct mechanical link to the engine and shifter in a manual tranny. An automatic has a liquid filled torque convertor that only has a solid link to the engine when the TC lock is turned on, which is usually while cruising above 40-50 mph. Since there is no solid link, the TC acts like a liquid filled vibration isolator, and does it pretty well. Then on top of that, the shifter in and auto is either by a cable or electronic, MB being the latter so you wont get any vibration felt only in the shifter and not the entire car.
Old Apr 30, 2005 | 03:13 PM
ctC230K's Avatar
Originally Posted by Capt Nemo o2
Naturally you would feel more vibration with the A/C on. Your engine is now running an extra kompressor, which could use around 25-30 HP. Thats quite a bit of strain to put on the engine at idle and not have any extra vibration. And like Outland said... There is a direct mechanical link to the engine and shifter in a manual tranny. An automatic has a liquid filled torque convertor that only has a solid link to the engine when the TC lock is turned on, which is usually while cruising above 40-50 mph. Since there is no solid link, the TC acts like a liquid filled vibration isolator, and does it pretty well. Then on top of that, the shifter in and auto is either by a cable or electronic, MB being the latter so you wont get any vibration felt only in the shifter and not the entire car.
Old May 1, 2005 | 08:08 PM
Thnaks guy's. I realize I would feel more vibrations w/ A/C on. My main concern is the "knock" (about 2 per second) I'm feeling.
Old May 1, 2005 | 10:34 PM
Outland's Avatar
Go ask your dealer to sit in another one with the AC on, and grab the stick.
Old May 2, 2005 | 09:24 AM
ctC230K's Avatar
that sounds so dirty :p
Old May 2, 2005 | 11:51 AM
Not sure about your area, but manual MB's are RARE in the southeast.
Old May 4, 2005 | 07:51 PM
jigga619's Avatar
2002 C230
I have a manual, and I too feel the vibrations when sitting at a stop light (w/ no AC on). I'm taking my car in tomorrow to get it checked out.. so I'll let you know what happens.
Old May 4, 2005 | 08:45 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Don't hold your breath - nothing will happen, you will have wasted your time. As many stated here, vibrations in the stick at idle are normal.
I suppose this is more pronounced in 2005+ gear box with solid linkages between the stick and the box itself as opposed to the pre-2005 version that has cable links.
Old May 4, 2005 | 10:08 PM
AGAIN, I realize you're going to feel vibrations through the stick. I'm concerned about the 2 knocks pers second I feel through the stick sitting at idle, with the A/C on, after you've been driving for a while.
Old May 4, 2005 | 10:14 PM
vadim's Avatar
Jim--
I do not feel knocks with AC on, but we have different transmissions. Have it checked at the dealer. And to get peace of mind, try to find another 2005+ MB with a manual tranny (does not have to be a C-Class SS, BTW), and see if it is present.
Old May 4, 2005 | 11:24 PM
mick1's Avatar
2005 C320wz
no 2 knocks per second on my car.
Old May 5, 2005 | 05:03 PM
Do you notice any change in the vibrations through the stick while sitting idle w/ the A/C on and after having driven for a while?
Old May 5, 2005 | 09:13 PM
mick1's Avatar
2005 C320wz
Nope. on the V6, it's the same all the way through. there's vibration with the A/C off and with the A/C on, the vibration level stays the same (after an hour of driving). The engine's vibration caught my attention the first few days i drove the car because my old '99 bmw 328i had less vibration at 75,000 miles than my C320 at 18 miles. On the bmw, sometimes I could not tell if the engine was running. However, the vibration on the C320 isn't all that much, so I got used to it
ctC230K's Avatar
lol @ Jim. i thought you said u were gonna trade it in for an auto??
Old May 5, 2005 | 09:24 PM
The story of my trip to trade it is in the thread titled "Wild coincedence!". Suffice is to say that I don't want to lose that much money since my car is 99% the way I want it. I "may" retrofit an auto tranny in it in the not-to-distant future if I don't start enjoying shifting gears.
Old May 5, 2005 | 09:35 PM
Thats the beauty of inline 6's They are so smooth. They are the most naturally balanced engine of any piston configuration other than V12s which is nothing more than 2 I6's
Old May 5, 2005 | 09:39 PM
ctC230K's Avatar
ohhh that's right. what ever happened ? sorry i can't remember. did you trade with him?? oh wait nevermind. i should read more then the first line of posts sometimes but i'm moving in lightspeed right now, i have no time for anything anymore.
http://home.earthlink.net/~ct323i/carerragt/
Old May 5, 2005 | 09:48 PM
vadim's Avatar
... you forgot to mention the boxer
Old May 5, 2005 | 10:38 PM
ctC230K's Avatar
you mean the boxster right? hahahaha
Old May 7, 2005 | 12:01 AM
vadim's Avatar
No, idiot, I meant "boxer". Noone it talking about Porsche here.
