Brakes are squeaking, need help.
To check the rotors you need a micrometer and a dial indicator. Measure the thickness with the "mic". If near or less than the minimum thickness, you need new rotors. If they are thick enough, use the indicator to check runout. Ask the rotor salesman what the specification is for your car. Figure on needing a rotor change every other set of pads on the front, and three or four sets on the rear. The rotors are not expensive, even at the dealer, so it no longer makes sense to refinish them in the workshop.
