Brakes are squeaking, need help.
If the pads and rotors are ok then what is causing the squeaking/squealing? Why would this problem suddenly pop up? I mean when the car was new it didn't do this. It must be a wear issue or something. Otherwise the brakes would have been doing this from the start.
The pads I buy in Europe are made by ATE, and have a piece of double stick tape on the rear side. It is very thin tape, like ordinary Scotch tape in thickness. You peel off a brown backer tape, and the pad then sticks to the piston. I was told this tape prevents squeaks, and does not put any greasy stuff like the paste near the friction surface of the pad or the rotor.
Use the paste. Remove the wheel, undo the TOP bolt of the pad carrier. Remove the pads and coat them with the paste. Should work fine, unless you have a problem, a real one like excessive run out on the disks. In this case, having them turned (machined flat again) or new rotors will do.
Worthy of note;
Ideally, you would not actually run rotors against pads. How's this work? I don't know but, if every once in a while, when the family is not in the car, you do 6-8 80 mph to 10mpg hard braking efforts in a row (you know you're ready to stop when you smell the cooking brakes), then allow them to cool by driving down the hwy without applying the brakes, it will transfer a thin layer of "brake pad material" to the rotors. That will also stop the squealing and your brakes will work much better. The whole concept has something to do with adherent and abrasive friction. I know it's detailed well enough on page 119 of the June 2005 Grassroots Motorsports magazine
Have an 05, no squeaking for the first 63,000 miles. However, just changed rotors and pads about a month ago, only squeaks when i brake on reverse. Have no solution to this but maybe it needs some time to break in.
Tom (nukblazi) had one of the best C-Coupés in the USA.
I took his advice frequently and freely. The hard-stop braking procedure he described worked for both my W203's (Sport Coupé and Sport Sedan).
I love Mercedes and I have had almost no problems with this car. But this is unacceptabe. I am not paying for them to lubricate the brakes, and if this continues they are doing it for free. A Mercedes-Benz should not have squeaky brakes.
They still squeaked afterwards a little bit....Now are they talking about speeding up to 50 and then slammin on the brakes????
Or just going about 35 and slammin the brakes?
but
If I feel that they start to not work well in any way, I will have the checked immediately, but not too worried about it at the moment...although would love to get some brake pads that don't leave as much dust when ever I have to replace the pads...I've read the other threads about which pads are good..
but
I should tell the people at the dealership it is in their best interest to fix my squeaky brakes, it is bad advertising for people to see Mercedes constantly squeaking.
