I'm using my "ESP" less and less...
Maybe it's just a mind-trick, but it does seem to handle better, leading me to think that the ESP is too aggressive in application (too conservatively sensitive... comes on too soon to keep me out of trouble).
Anyway, anyone observe similar changes?
traction control link
I have not tried this on my own car.
The steering does not hit as quickly with the ESP on and you would not see the dash light up for that one. You only really see that light up when it looses traction in the front such as going fast thru turns or over bumpy road. Im gonna guess the throttle response will seem quicker as well since the system is not trying to correct anything from take off. But its there to keep you out of trouble, as you stated. The fun starts when you start to get into some trouble.
On a side note, my ESP engaged the other day and I was very impressed. I was making a left at a corner somewhat quickly, where they had just done some paving. Some loose gravel was in my path and as soon as I felt a little slip, the light came on and the car continued on my intended path "like magic".
It simply monitors vehicle direction and compares it to various "inputs", like steering angle, yaw rate, wheel spin, etc. It applies the brakes individually at the appropriate wheel(s) and may cut engine output, but again, I don't think it does anything with the steering system. MB-BOB, I don't think it affects throttle response unless it detects wheel spin or vehicle slip. IMO!
It's just that when you're cornering at or near the limits of adhesion or a little over, the system does its thing by cutting output and applying differential braking to maintain your controlled turn direction (maybe too early, in my opinion).
While this is going on, mashing the throttle to take off won't have any effect until the system relinquishes control of the throttle to you, hence the perceived throttle lag. With ESP "off," I think I can get on the throttle faster. There, I think I said it better this time. Try it and see what I mean.
The ESP light does NOT always flash. It was raining last week, and it was late into the night, so I decided to go into this industrial park and see how my car handles in the rain.. took a couple of hard turns at speed. And most of the time the ESP didn't flash. Should be noted though that I wasn't on the gas during the turns, just yanking the steering wheel. But I *DO* feel the ESP. The car just seems to slow itself down mid-corner. Okay, I'm no pro-star test driver, but that's how I thought I felt.
ESP seems to only flash under power or as vinmanc32 said, during extreme circumstances.
As for the car feeling so much sportier with ESP off, I don't know. I'm thinking if I'm feeling playful, then I'll turn it off and I'm a bit more aggressive, so it's probably a mental thing.
MB-Bob I am with you in that the ESP on button retards throttle response ever so slightly. I have heard that with ESP on you can lose up to 20% of your torque on an E55. I don't know if this is entirely true but I swear I get better daily runs with the ESP off. The car seems to shift quicker and the drive-by-wire throttle responds better, especially on uphill climbs.
Even with the ESP button off the system is not truly shut down but at least it is diminished. I have only driven with my ESP button on when it rains since I ran those 0-60 runs. Your daily driving will be more fun.
