Smoky Burnouts for all 203 owners
Old Dec 1, 2001 | 12:28 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
I don't know if anybody outside of the dealer is aware of this, but the traction control can be completely disabled simply by use of the steering wheel buttons. Here's the low-down-
1. To start, the key must be removed from the ignition.
2. Insert the key and turn to position 1.
3. Immediately press and hold the trip odometer reset button until the instrument cluster beeps. There is no visual message, only an audio beep. Be patient, this takes around 40 seconds.
4. Press the lower menu button (it looks like two sheets of paper, the one with the writing in the background behind the blank one)
5. Press the up arrow button.
6. Press the "+" sign to disable the Traction System (turn "ON" test mode)
7. Start the engine, the traction system is now disabled.
To return to normal, remove the key and restart the engine. The traction control warning should no longer be in the cluster. If it is, shut the engine off and remove the key again. Then insert the key and turn to position 1. Note that the DYNO test screen is displayed immediately. Push the "-" button to enable the traction system (turn "OFF" test mode)
NOTE: When you first turn the key to position 1, ESP DYNO Test screen pops up, then after 1-2 seconds it may disappear while faults are displayed. If you weren't fast enough in pressing the "-" button before codes were displayed, just wait until all codes cycle by, then the ESP DYNO Test screen will reappear.
No, this doesn't work for any car but the 203, before you ask.
Enjoy, and I'm not buying you new tires!
Old Dec 1, 2001 | 01:36 AM
Blue Benz's Avatar
What's with all these secrets? This, the norway mode for the alarm......
Good to have someone on the inside, thanks.
Also, do you have any idea this why this only applies to the W203 C-class and not other newer MB's with the steering wheel controls?
Old Dec 4, 2001 | 09:12 PM
madryan's Avatar
2002 C230k
i thought wen you switch the ESP off.... the traction control cuts off?....
i guess i thought wrong...
thanks
Old Dec 4, 2001 | 09:25 PM
todd's Avatar
C230K
Performance 'easter eggs' ;-)
Old Dec 9, 2001 | 06:57 PM
DtS's Avatar
DtS
C200 Kompressor
Talking More questions to the already busy mbtech!
Not only does this disables the ESP. It disables the ABS and BAS as well. Tested this "feature" today and was pretty impressed.
Ok, now on to my questions:
At first I was able to scroll around in two menues. One with the ESP-disableing stuff and one with alot of numbers of wich I only understood: Eng-oil-lev. Kind of cool. I told me I had 6.3 litres of oil in my pan... Ok, when I was in this menu, I pressed and held up-arrow and plus-button for about 10 secs. Then a new screen appeared, with some other numbers of wich i didn't understand a single one. I think the heading in this third hidden menu was someting like SW03.
What was it that was displayed to me?
Just curious....
Thanks in advance!
Old Nov 23, 2002 | 08:53 PM
Blaxer's Avatar
The technique described in the original post does not seem to work on a 2003 C230. Could someone please post updated 03 info?
Thanks,
Blax...
Old Nov 25, 2002 | 01:03 AM
Lynn's Avatar
At this point in time, no one know how to do this, or even if it can be done at all.
Old Nov 26, 2002 | 02:58 PM
pokerFACE's Avatar
i've done it on my 2001..
can't get any wheelspin though
Old Nov 27, 2002 | 01:44 AM
Lynn's Avatar
We were talking about 2003's. This feature has been eliminated on the 2003's.
Old Nov 27, 2002 | 06:47 AM
patrick's Avatar
The procedure has changed, but it is still there.
For different reasons MB-service personnel should not tell the customers.
One of the reasons is warranty.
If someone disabled the ESP (completely) it cannot be known afterwards, even with the Star Diagnosis computer.
So if something happens then, the warranty department never knows if it is something that is not supposed to fail, break, etc...
Old Dec 9, 2002 | 01:54 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Re: 2003
Originally posted by Blaxer
The technique described in the original post does not seem to work on a 2003 C230. Could someone please post updated 03 info? Thanks, Blax...
Blaxer, other '03 owners... Using the procedure above (through step #3), can you get the dash to beep at least? I'm wondering if it beeps, then maybe the feature is there but with different wheel button pressings required. Ideas?
Old Dec 9, 2002 | 04:27 PM
DtS's Avatar
DtS
C200 Kompressor
I have a very strong feeling that patrick knows how to do this
Old Oct 22, 2007 | 02:43 AM
harrance4's Avatar
2006 c230
umm ?, i dont get "If someone disabled the ESP (completely) it cannot be known afterwards, even with the Star Diagnosis computer.
So if something happens then, the warranty department never knows if it is something that is not supposed to fail, break, etc..." explain please, does this mean that if u turn it off u can never turn back on, or like the warranty people will know u turned it off and ur not covered or anything, whats the deal with it. i didnt understand
Old Oct 22, 2007 | 08:17 AM
ozoz's Avatar
2001 c200k with kleemann pulley
cool stuff ... i'll give it a try this weekend ... cos i have a 2001 ...
Old Oct 22, 2007 | 04:58 PM
Klaufi's Avatar
'05 C230 Kompressor - Sport
Ohh man, i was hoping this would work with the 2005 =/
I hate the traction control/ESP..
Know of any easter eggs in the 05+ w203?
Old Oct 22, 2007 | 05:09 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Search for "dyno mode". Here and in the AMG forums. 2001-2002 models have different steps than 2003-2007 models.
For 2003-2007 models:
1) place key in position 1
2) toggle through menus until you are at the trip odometer (overall mileage)
3) press the reset button 3x's in a row
4) Instrment Cluster should beep and show the battery voltage
5) Use page buttons to switch to dynometer test screen
6) scroll up to highlingt ON for dyno/test mode
that's it. Anybody have any other questions, search for dyno mode. I may have even stickied it at the top AFTERMARKET/DIY STICKY.
Old Oct 22, 2007 | 05:32 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
still no burnouts in dyno mode...
Old Oct 22, 2007 | 05:38 PM
rlee02135's Avatar
2004 C32 ///AMG
whats the best way to do a burnout?
I know that revving in Neutral and slamming into Drive is terrible on the tranny...
And I don't think I could hold the front brakes while spinne=ing the rears, because of the Stopteck BBK.
Old Oct 22, 2007 | 05:58 PM
Klaufi's Avatar
Yup,
You made it a sticky, found it just after i posted it..
Still, if any1 knows of other easter eggs, keep em coming!
How does Dyno mode affect driving the car? Does it do anything bad for it?
W/R Eyfi
Old Oct 22, 2007 | 06:06 PM
Klaufi's Avatar
Posted that reply twice *Newbsmile*
Old Oct 22, 2007 | 06:08 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
i have a 4matic so thats out... lol anyways wouldnt want to kill my tires anyways
someone should start a easter egg sticky thread!
Old Oct 22, 2007 | 09:07 PM
benzboi3's Avatar
05 C230K SS 6MT, 00 Audi TT 180Q 5MT
ive got a 6 speed manual and i cant even get smoky burnouts with dyno mode, chirps are no prob but...
Old Oct 23, 2007 | 09:42 AM
EnkeiDynamics's Avatar
02 C230 Coupe
Wow this is awesome I'm going to try it out at lunch...
New tires FTW!!
Old Oct 23, 2007 | 03:46 PM
02 C230 Coupe
Ok...so i tried this a lunch to day and it works...but when I was about half way through a u-turn I floored it (I had the car in 1st gear, using the autostick feature) but it wouldn't GO...it just responded as if I had rounded the corner normally, then I noticed I was stuck in 2nd gear and it wouldn't shift any further. I was able to drive back to a parking lot, park and restart the engine to fix it but it did it again after trying to do the same u turn........whats up with that?
Old Oct 23, 2007 | 06:11 PM
bensitto's Avatar
S550, R350, GL550, ML63 AMG
My C320 does crazy burnouts with DYNO mode on. You need to hold the brake down with your left food and accelerate with the other until you break traction. After you break traction you can release the brake, keep the accelerator down and launch... Similar to launching on a drag strip but you don't wan't to break traction at the track. Only did it a couple times but lots of fun.
Haven't done it since I got my new tires.
